Just trying to kick it down the road a little farther.
It will occasionally work. These are the most common error messages. on start up Unable to read Location 0x00380045 0x78302044 0xFF534758 0x00000000 ==== Could not create a new document because Pro Tools could not set sample rate to specified value.. If it allows me to enable ethernet controllers I sometimes get an out of memory error. Thoughts? |
2 new error messages
Unable to read Location 0x002D0036 and a runtime error for R6025 -pure virtual function call |
Not sure why you are posting/what you expect here.
Pro Tools 9 ancientware was never designed to run on Windows 10. The Pro Tools compatibility information is documented here: https://avid.secure.force.com/pkb/ar...tibility-Chart Not being officially supported would be a good reason to give up, and you are unlikely to find folks here to hold your hands trying to make this work. There are some old threads on DUC about getting Pro Tools 8 or 9 running on Windows 10 that you can look for. Not that it will likely help you much in this case but basic troubleshooting and the kind of information you should supply if seeking help on DUC is under the “Help us help you” link up the top of each DUC web page. |
Indeed^^^^ You might consider moving to a modern version of Pro Tools and then adding the Nyrinck program that allows the ProControl to still function as a HUI device
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C https://www.facebook.com/search/top/...0sound%20works I started in this business with nothing..........and I have most of it left ![]() BTW, my name is Dave, but most people call me.........................Dave |
ProControl with 7.0/7.1 LE (procontrol.dll etc) | eccles | ProControl, Control|24, Command|8 | 0 | 09-17-2010 01:06 AM |
New ProControl | worldsound73 | ProControl, Control|24, Command|8 | 28 | 03-29-2004 05:32 PM |
DIGI 001 and Motu 2048 MK II or Motu 24i+ Logic Audio | cyril | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-19-2002 10:08 PM |
HUI or ProControl | djf | Pro Tools TDM Systems (Win) | 0 | 02-23-2000 01:10 AM |
ProControl & NT | Camilo Orozco | Pro Tools TDM Systems (Win) | 4 | 02-16-2000 08:06 AM |
