Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 08-15-2020, 11:54 PM
joy128 joy128 is offline
Default sessions wont create or open in pt first
Can someone please help? Every time i try create a new session it opens for a split second and then gives me an error message and shuts the pt down completely
"Comments
Some inputs or outputs may have become inactive because your audio hardware device has changed."
is what it says...
i have a scarlet 2i2 3rd gen hooked up to it
thanks!
Old 08-16-2020, 12:16 AM
PatJo PatJo is offline
Default Re: sessions wont create or open in pt first
That error message simply means that the templates you based your project on were not created with the same hardware. You can ignore that message.
Not sure why PT is closing after that though. That shouldn’t happen.
Old 08-16-2020, 12:29 AM
Pro Tools First also does not work with Session files. It works with Projects. A sad crippling/lack of compatibility with Pro Tools.
Old 08-16-2020, 12:48 AM
i am creating the "project" from the template that they provide. so i am not doing anything outside of their own protocol... Also i am not switching hardware, brand new pc, focusrite and pt
thanks
Old 08-16-2020, 01:00 AM
Exactly. The templates that are provided were not created with the same hardware you have so you get this “warning”. It’s normal and although a little disconcerting it only happens when you create the project initially. It is not an issue and I suspect is not related to your actual problem which is that PTF shuts down on you.
Old 08-16-2020, 11:26 PM
ok. so what is the issue? how can i get it to work?? please help!
Old 08-17-2020, 05:35 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
As Darryl stated, PT First will only load "Projects". Try creating a Project and see if it has any check boxes that load Project templates. It has been a while since i used PTF and don't know if it allows using templates cof any kind at all TBH
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 08-17-2020, 06:40 PM
I am unable to create anything at all... The pt shutsdown on me right away after giving that error message that I typed earlier...!
Old 08-17-2020, 08:25 PM
So what Audio device is Pro Tools trying to use?
Did you install the latest drivers for the 2i2?
Make sure Windows sound and other apps are *NOT* set to use the 2i2.
Start Pro Tools while holding down the 'N' Key and keep it held down until you see a Playback Engine dialog box. In that box's pulldown select the 2i2 as the playback engine. If there are multiple confusing choices tell us exactly what you see.
You must be using the *ASIO* driver for the 2i2 with Pro Tools. Make sure you are installing the correct drivers for your version of the 2i2.
Old 08-17-2020, 08:37 PM
yes its the usb focusrite asio option in the little dialogue box that pops up that i am choosing... I downloaded everything from the focusrite site, and had tech support connect to my pc to check it and he didnt find any issues.. none the less am i not supposed to be on the asio? thanks!
PTools wont open files or create new ones mbzc111 Pro Tools | Intro Discussion 0 04-26-2018 01:36 PM
Pro tools mp9 wont open sessions austinerary macOS 1 06-25-2013 08:34 AM
Reconstructed sessions wont open gaas Pro Tools TDM Systems (Mac) 7 01-13-2011 09:53 PM
Major Problem - Cannot open or create any sessions on PT 8.0cs3 LE FDPT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-08-2009 02:11 PM
cannot open or create sessions ! sterling123 Pro Tools TDM Systems (Mac) 3 09-06-2007 08:35 AM
