Old 11-09-2011, 11:29 AM
robinsonsdca robinsonsdca is offline
Banned
Exclamation Midi 101 really missing? Set high note/low note on track's input
Hello
Can't find the most basic of functions. Limiting a track's input midi note range, setting high note/low note on the track itself. It must be somewhere. Found it in Logic, Ableton, Cubase, Cakewalk and Digital Performer. So it must be somewhere in ProTool's track menu. (some AIR instruments don't have their own note range seletor, so it must be on the track somewhere) Pro Tools is the best isn't it? It should be there somewhere then?? Please help
Old 11-09-2011, 12:08 PM
dterry dterry is offline
Default Re: Midi 101 really missing? Set high note/low note on track's input
Not just you. It is missing. Midi tracks' Real Time Properties includes quantize, duration, delay, velocity range limit and transpose, but not note ranges.
I agree, PT needs note range limit - along with velocity scaling, and cc scaling and remapping.
Old 11-10-2011, 10:04 AM
Banned
Dterry
Well I have to look at this financially
So a $10,000 Pro Tools HD system will not have this feature (or at any price)
But a $100 Ableton Live Intro will(and all the other daws for their fractional price)
I'm starting to second guess my involvement here..
Old 11-10-2011, 12:45 PM
whitewrabbit whitewrabbit is offline
its been long known that pro tools is not a best midi solution out there. yes it is a complete production suite, however it's only industry standard for its studio operations. For midi your better suited using reason, digital performer logic or ableton (though i hate logic) personally i use pro tools for studio, mixing and mastering. i use reason for most VI's and ableton for most other midi. it's also well known that digi/avid is unmotivated to add features that most other daws support, example 32 bit float has been around for years yet PT 10 made it seem entirely new.
Old 11-10-2011, 01:23 PM
Banned
Exclamation Re:Midi 101 missing? -just Run Pro Tools as a Plug In
Whitewrabbit
thanks for your empathy. So Avid may be unmotivated to add midi features, but Avid's motivation for advertising knows no bounds. And the message comes across that Pro Tools is a medium for a musician's creativity, so I and many feel mislead. I mean you can't even map AIR effects to midi CC controllers. And euphonix and automap are cumbersome solutions. Forget Maudio controllers. And there is no RTAS to VST adapter. Another unique AVID quality. Once again to block outside influence-
PT8 - Missing first midi note? InRainbows 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-25-2008 11:42 AM
Midi recording early (and missing the first note) tripstation MIDI 0 09-11-2008 04:14 PM
EXPORT MIDI from Stryke NOTE FOR NOTE... riggi Virtual Instruments 1 03-10-2008 07:32 PM
First midi note Hit always missing. cwhite771 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-01-2003 12:20 AM
Missing 1st Midi note ? roaddog215 Pro Tools TDM Systems (Mac) 2 11-16-2000 05:03 AM
