  #21
Old 01-02-2018, 05:13 PM
Default Re: ProControl Technical Assistance
Originally Posted by DJ Rae C View Post
I'n actually a Film Studies student getting into post-production, and tutors are about as helpful as wet sand
Congrats on getting it working.
  #22
Old 01-03-2018, 09:36 AM
Bookerv12 Bookerv12 is offline
Did you get it working?
bookerv12
  #23
Old 01-03-2018, 03:35 PM
DJ Rae C's Avatar
DJ Rae C DJ Rae C is offline
You are correct about the D-Sub 25 to D-Sub 25R cable, but it only applied to models with the following series number NX18*31 or lower, mine is NX30048 so modification already been dome and doesn't required D-Sub 25R
  #24
Old 01-03-2018, 03:36 PM
DJ Rae C's Avatar
That the way Ive set it up, output wise through the output section
  #25
Old 01-04-2018, 10:41 AM
DJ Rae C's Avatar
System is up and running via 96 i\o audio in\out, turns out the input d-sub cable was in wrong port swap them over and audio kicked into life
  #26
Old 01-05-2018, 12:06 PM
DJ Rae C's Avatar
By adding via light pipe and using the 192D as expansion I now have audio from both 96 and 192D via a ADA8000, using B7-8, checked today with Se M1C mic and can confirm out in and out, and still to use input 2 on rear of PC.
Thanks to all that offers and gave advise, especially Eric @ Mediapsec who was a mind of information, and put me on the right track FOC, much appreciated
Could someone give me a bit of technical help? Snowblind Pro Tools M-Powered (Win) 2 12-28-2010 06:50 AM
Need some technical help... TAMA Pro Tools M-Powered (Win) 0 03-12-2010 06:50 PM
Technical set up help! jiagap 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-07-2005 07:05 AM
TECHNICAL QUESTION Pete Weaver Pro Tools TDM Systems (Mac) 4 04-09-2002 09:58 AM
2 technical Q's gabriel_p 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-20-2002 12:07 AM
