Old 11-29-2017, 01:06 PM
Zep Dude Zep Dude is offline
Default IO Insert mono to stereo with delay comp?
Hi, my system is down right now so I am unable to check this. Can someone tell me if the hardware IO Inserts would allow this set up and also have correct delay compensation for the inserts?
Insert:
Out 1 > external FX ---> In 1
________________\---> In 2
Insert:
Out 3 > external FX --- >In 3
________________\---> In 4
Output:
Out 2 Stereo Mix L >2 track tape
Out 4 Stereo Mix R >2 track tape
I'm trying to remember if PT lets you do a mono insert to stereo return (with proper delay comp on both channels).
Much appreciated!
Angelo Montrone
Majestic Music
Studio / Label: www.majesticmusic.com
Old 11-29-2017, 02:20 PM
Drew Mazurek's Avatar
Default Re: IO Insert mono to stereo with delay comp?
Hardware Inserts need to use "stacked" I/O in order to be compensated for properly.
So if the send is 3-4, the return would be 3-4 also.
www.drewmazurek.com
Old 11-29-2017, 03:01 PM
Thanks, I kind of suspected that.
Angelo Montrone
Majestic Music
Old 12-01-2017, 11:09 AM
Additionally, if your hardware unit is a time-based effect unit(reverb/delay), I would probably not use it as an insert and would send to it, and return it to a new stereo track
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas..............................
www.capricornsoundworks.com
Old 12-04-2017, 08:43 PM
That's throws off the timing since the delay compensation algorithm does not know how to handle it? For example, your timed delay may no longer be in sync with the beat.
Angelo Montrone
Majestic Music
Commit Up To This Insert bug with mono>stereo plugin jacko Pro Tools 12 5 06-02-2018 09:54 PM
Mono Send with Stereo Return via Insert Schwabbl Pro Tools HDX & HD Native Systems (Mac) 1 11-26-2013 11:56 AM
HW insert delay comp in PT11 (and OMNI question) Tim R. Pro Tools HDX & HD Native Systems (Mac) 3 04-14-2013 01:54 PM
Hardware Insert Delay Comp Issue therecordinghouse Pro Tools 9 7 11-17-2010 06:01 AM
Mono Insert consumes stereo I/O acacia Pro Tools TDM Systems (Mac) 19 08-04-2010 03:39 PM
