Old 11-20-2017, 06:19 AM
Raoul23 Raoul23 is offline
Default One fader not responding all the time??
On my command 8 fader 5 sometimes responds and sometimes doesn’t. Any tips for sorting this it seems to be an intermittent problem
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 11-20-2017, 12:35 PM
Tweakhead Tweakhead is offline
Default Re: One fader not responding all the time??
It's likely to be one of 4 things (in order of least severity first):
0. Exercise the fader a lot.
1. Fader slider needs cleaning. (Remove, clean, refit, recal)
2. Fader/Fader chip is dying. (Find replacement, and replace)
3. Controller board is dying. (Find replacement, and replace)
A good tech that can fix these is probably already in your contacts. (I hope)
Old 11-27-2017, 05:16 AM
Neil H Neil H is offline
Most likely the fader's carbon track is dirty and needs cleaning or has worn away the carbon.
If it were a board problem its most likley all faders would be exhibiting the same issue as they are processed in a bank of 8.
Pro Tools HD 10/12
Pro Control & Fader Packs
Artist Transport & iPad Control App
Join the Facebook Pro Tools Windows User Group
Old 11-27-2017, 11:02 AM
Thanks Neil for chumming in I fixed this the other day, by squirting some contact cleaner in the fader and re calibrating. So far so good
Raoul Crane
Old 11-27-2017, 01:40 PM
No problem, although contact cleaner is not really a great thing for fader tracks as it attracts dirt to stick and gunge up which is then abrasive to the carbon track.
The tracks are designed to run best dry.
Ive made some videos about cleaning faders properly on a control 24 (which are the same as a command 8) but havent edited or uploaded them yet but will let you know when i have.
Pro Tools HD 10/12
Old 11-27-2017, 01:50 PM
Thank you, look forward to seeing these so I can clean mine properly
Raoul Crane
MC Control - fader not responding hugoleitao Artist Series 0 01-01-2016 05:29 PM
Artist Mix not responding to fader touch ilovemyssl Artist Series 1 05-12-2014 10:06 AM
Fader not responding to touch PTPerson ProControl, Control|24, Command|8 5 06-09-2012 01:29 AM
mixer meter not responding to fader hoss33 Tips & Tricks 4 11-23-2009 11:21 PM
FADER MUD - IMPOSSIBLE TO MAKE FADER WRITES IN REAL TIME Jim Casey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-22-2007 11:34 AM
