Old 11-14-2017, 06:36 PM
busk busk is offline
Default Plugins and Routing Options not showing PT 10
Anyone else ever had this issue: Pro Tools 10 will not show any plugins or routing options unless the mouse is moved over it. This started happening using a mac with OS 10.8, the same OS PT 10 was installed with. I've since upgraded to Sierra, and it still happens. I realize this version of PT is unsupported now. I've included a screenshot to better illustrate what's going on.
Click image for larger version
Name:	Pro Tools Screen Shot 2017-11-10 at 7.20.55 AM.jpg
Old 11-14-2017, 06:41 PM
Drew Mazurek's Avatar
Default Re: Plugins and Routing Options not showing PT 10
you sure about that?
This is a known issue with running 10 with the newer OS.
You either update to 12 or downgrade the OS, it's that simple.
www.drewmazurek.com
Old 11-15-2017, 06:14 AM
The symptom you're showing actually started happening with OSX 10.10.x. OSX 10.8.5 and OSX 10.9.x run PT10.3.10 no problem. The only reason PT10 isn't officially okayed by Avid for OSX 10.9.x is because the uninstaller doesn't work but there are manual steps to accomplish that on Avid's site.
Jack
QAPLA!
Old 11-19-2017, 04:12 PM
It was going on for months before I updated the OS
Old 11-19-2017, 04:15 PM
That's interesting you mentioned 10.3.10 no problem. I was having this issue with PT 10.2, and overlooked updating it before I changed the OS. Thanks.
Old 11-19-2017, 06:48 PM
What OSX version did you update from? OSX 10.8.5 runs PT10 no problem; the only problem with PT10 and OSX 10.9.5 is the PT uninstaller doesn't work but functionality is all it should be with no menu errors like you see in OSX 10.10.x and above. If you actually had the blank insert menu problem in OSX 10.8.5 you have other problems going on that are not PT related.
Jack
QAPLA!
PT 11 HD with HDX plugins not showing up garnoil Pro Tools HDX & HD Native Systems (Mac) 7 09-28-2013 05:02 AM
output routing options stainless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-19-2010 01:33 PM
Plugins not showing up Royalston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-03-2006 02:58 PM
Plugins not showing up subaro0o 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-10-2006 01:25 PM
TDM Plugins not showing up... JLEpperson Pro Tools TDM Systems (Mac) 0 03-01-2001 03:19 PM
