Go Back   Avid Pro Audio Community > Pro Tools Software > Avid Cloud Collaboration
Old 12-22-2016, 12:59 AM
clausiii's Avatar
clausiii clausiii is offline
Default Re: Cloud Collab bug with plugin automation
12.7 has this problem too, still upload updates out of nothing...
opened a support case....
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 8GB RAM
ProTools 2018.12
Digidesign Command|8
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
tons of stomp boxes
tube amps
guitars
noise
Old 12-22-2016, 10:25 AM
jeffro's Avatar
jeffro jeffro is offline
Sorry I didn't see this thread earlier. Will check this out today and report back.
Old 12-22-2016, 10:34 AM
clausiii's Avatar
Thank you jeffro!
i attached a video in my support case which explains the problem.
My ears! My ears!
clausiii
ProTools 2018.12
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
tons of stomp boxes
tube amps
guitars
noise
Old 12-23-2016, 12:33 PM
clausiii's Avatar
Hey Jeffro! Any news? I've found people with similar problems in the AiR forum. But no solution yet.
My ears! My ears!
clausiii
ProTools 2018.12
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
tons of stomp boxes
tube amps
guitars
noise
Old 12-23-2016, 04:54 PM
jeffro's Avatar
I was able to repro as well with plug-in automation but not with vol/pan/mute/trim. Will log a bug from your support case - thank you for the detailed info.
  #16
Old 12-24-2016, 12:35 AM
clausiii's Avatar
Thank you! Merry Christmas!
My ears! My ears!
clausiii
ProTools 2018.12
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
tons of stomp boxes
tube amps
guitars
noise
  #17
Old 12-24-2016, 12:52 AM
clausiii's Avatar
Default Cloud Collab bug with plugin automation
Btw! Maybe my English is bad but there was a misunderstanding: the regular track automations like vol, pan, trim, mute work as expected!! It's only plugin-automation!
My ears! My ears!
clausiii
ProTools 2018.12
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
tons of stomp boxes
tube amps
guitars
noise
  #18
Old 02-04-2017, 03:51 AM
clausiii's Avatar
Any news on this? I use VI automation a lot but this bug makes automations in CC nearly unusable.
Thanks
My ears! My ears!
clausiii
ProTools 2018.12
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
tons of stomp boxes
tube amps
guitars
noise
  #19
Old 02-07-2017, 07:05 PM
jeffro's Avatar
Bug is still open. I update the description for http://protools.ideascale.com/a/dtd/257559-3779. If this is impacting others please start a support case and reference PT-221813.
  #20
Old 02-23-2017, 12:29 AM
clausiii's Avatar
bug is still present in 12.7.1...
My ears! My ears!
clausiii
ProTools 2018.12
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
tons of stomp boxes
tube amps
guitars
noise
Cloud Collab bug with plugin automation clausiii Pro Tools 12 2 12-09-2016 12:15 PM
Pt 12.5 cloud collab says my projects are used up but i havent used any yet HALO1THEGREAT Pro Tools 12 2 05-09-2016 04:51 AM
Removing Application Manager and Cloud Collab? jjnssn Pro Tools 12 2 05-01-2016 12:35 PM
PT Cloud Collab Webinar 3/15 Tom Graham General Announcements 0 03-04-2016 10:46 AM
