Old 05-25-2015, 08:10 AM
critza critza is offline
Default Elastic Audio Freezes/Hangs Pro Tools
Hello, i have been experiencing this issue with both my computers and now i am working on a song, and in 15 minutes Pro Tools has crashed/hanged twice.
I activate Elastic Audio on a track , set it to ticks and start putting out warp markers after it has analyzed the audio, and suddenly i get the beachball and pro tools stops responding. I have left it on for minutes and then i have to force quit pro tools and restart it.
I am now on a
Mac Pro 2013
12 Core 2.7GHz
16GB Ram
HD Native (in a Sonnet Echo Express SE II Thunderbolt 2) + Omni
Recording drive
OWC Thunderbay 4 with 2 Samsung EVO 256GB in RAID 1
Pro Tools 10.3.9
OSX 10.9.3
I have Pro tools set to Autosave 3 minute intervals. Havent tested if this could be causing the problem, actually i dont really feel like spending time on doing this, id rather make music.
I have another computer at home and i have encountered this error on this machine as well.
Anyone have similar problems?
/Christer
PC 7980XE @ 4.2
PT 12.7 Ableton 10.0.1
Great River ME-1NV, Ehrlund EHR-M, Axiom Pro 49, Brauner Valvet, Oktavamod MXL-910, RODE NT5 with Oktavamod MJE-384K, Crane Song Trakker, SSL 611EQ, SSL X-Desk, Sennheiser HD600/650
IS Pro Double 6" Speakers, www.intelligentsound.se/
Old 05-25-2015, 10:11 AM
suicune suicune is offline
Default
Yes I've had it - quite a lot actually. To cut a very long story short it seems to only happen with monophonic mode so use polyphonic instead. Samples/ticks doesn't make any difference.
M2 Studios
Wolverhampton, UK
http://www.madhat.co.uk
Old 05-27-2015, 04:27 PM
Default
Thanks for your reply, havent tried to use only polyphonic, but ill try to stick with it, seems to be a bug though, if more ppl experience it.
PC 7980XE @ 4.2
Old 05-27-2015, 05:54 PM
amagras amagras is online now
Default
As suicune, it happens in monophonic mode to me too, not that often, tho
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools 2018
amagrasmusic.com
Old 05-28-2015, 05:39 AM
Default
Yes the other part to the story is that it only happens when the audio was analysed since opening the session - that is if you save the session, close it and reopen it you won't get a hang. Which is why it seems so intermittent - but if you put a monophonic plugin on new, or record new audio on an existing track with it on, then move a warp marker and start playback I found I was getting a hang a good 50% of the time in my experiments.
M2 Studios
Wolverhampton, UK
Old 06-02-2015, 09:21 AM
Default
Sounds about right for me too, got the same project hanging twice from doing something similar.
PC 7980XE @ 4.2
Old 07-20-2017, 04:36 PM
Dizzi45Z Dizzi45Z is offline
Default Re: Elastic Audio Freezes/Hangs Pro Tools
I am so tired of this bug. 12.7.1. I've tried this on several computers. The same thing happens on big sessions with me with Elastic Audio and XForm. It will render the first chunk of files and then freeze. It is almost like it fills up the RAM and then crashes. PLEASE FIX THIS AVID.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools 12.8.3 HDX Mac OS 10.12.6
Mac Pro Quad 3.2 Nehalem with 32 GB RAM
Noisebox Studios -Utah Recording Studio
Old 11-19-2017, 01:15 AM
maltastudio's Avatar
maltastudio maltastudio is offline
Yes Please fix this Avid the Industrial Standard bug 2017
Peace
www.maltastudio.com
https://soundcloud.com/charlesmuscat
MacBook Pro Late 2016
Intel I7 Quod Core 2.8 GHZ
16 GB Ram . 256 GB SSD
Mojave
Acer Nitro
Intel I7-6700-HQ
8 GB Ram 256 GB SSD x 2
Win 10 Home 64 bit
Motu 624 AVB , Yamaha 01V96i
Pro Tools Native 2019..Latest , Sonar Platinum Lifetime
Old 11-19-2017, 01:58 PM
This may be only on the Mac side as it doesn't happen on any of my Windows rigs. Random thoughts:
1-Don't bother with Ticks mode unless you are trying to alter the session tempo.
2-Separate the area you want to edit and try X-Form. Its takes longer as it renders each and every move(which is why I suggest cutting and working on sections that fit across your EDIT window).
3-if you see the audio snap back after moving a WARP marker, just click on that same WARP marker once more and the waveform SHOULD snap to the marker(this is a known bug). I have had this happen on both Windows and Mac systems
HP z820 12 core, 64GB RAM, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs, Warm Audio and Midas..............................
Elastic Audio hangs PT10 suicune Pro Tools Software (Mac) 21 06-03-2014 01:10 PM
Protools 8.0.1 intermittant freezes and hangs Phill Barrett Post - Surround - Video 18 10-30-2009 10:04 AM
Recording Midi freezes hangs Pro Tools jallen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-26-2007 07:17 AM
Opening Session Hangs/Freezes System ptal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-29-2006 02:34 PM
protools freezes/hangs/crashes/etc after about 20-60mins cazfair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-18-2001 06:57 AM
