Old 07-01-2014, 04:29 AM
adrianrobison adrianrobison is offline
Default PRO TOOLS HDX BUG FOUND! HDMI monitor the culprit!
So, I just bought Avid's Pro Tools HDX. I own a late 2013 MacBook Pro with maxed out specs. I am running Mavericks and Pro Tools 11.1.3. My HDX card is plugged into an HD I/O and is fitted inside of a Sonnet Echo Express III-D Thunderbolt 2 PCIe Chassis. The idea was to run HDX on my laptop... but...
Pro Tools wouldn't recognize my HDX card! I would try to change the "Playback Engine" to "HDX" but that option wasn't there! I would try to run DigiTest to see if the card was defective but DigiTest wouldn't open! I used my Avid Support Code and called them. After about 5 hours of deleting files, installing and reinstalling new and old versions of Pro Tools and new and old HD drivers, we ended up still puzzled... Until we came up with the idea to disconnect the HDMI cable that was hooked up to my Dell 2408WFPb monitor.
Boom. Problem solved. As it turns out, Pro Tools would only recognize HDMI as an option in the Playback Engine (HDMI transfers audio and video, hence why Pro Tools defaulted it to HDMI). When DigiTest would crash, it was because it was thinking the HDMI was the HDX. My solution to the problem was to buy a DVI adaptor and plug the monitor daisy chained thru the extra Thunderbolt port in my Sonnet Echo Express III-D PCIe chassis.
Ditch HDMI. Problem solved.
Hope Avid fixes this... it makes my nice and shiny HDMI port on my laptop look lonely.
If anyone out there has this problem, I hope my experience can solve your issues!
Hope this helps someone!!!
-Adrian
Old 07-01-2014, 04:55 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Default Re: PRO TOOLS HDX BUG FOUND! HDMI monitor the culprit!
Thanks for sharing.
I have passed this information on to Avid.
Old 07-01-2014, 10:28 AM
Hugh-H Hugh-H is offline
Hello adrianrobinson,
Thanks for the posting, we've used the HDMI on our Mac Minis just fine so it could be a MBP-specific problem. We also get the HDMI option for playback engine but we can select HDX.
No doubt you and the Avid support person went through everything, but I have a couple of questions if you don't mind.
1 - with everything plugged in did you launch ProTools while holding the "n" key to force a playback engine search? This has helped a few folks in the past with playback engine weirdness.
2 - If you launch ProTools with HDX, not plugged into the HDMI port, can you then plug in the HDMI monitor and use it?
Thanks,
Hugh
Old 07-01-2014, 12:38 PM
Guitarman002 Guitarman002 is offline
Yes...I use a Sony 50 inch television as a monitor via HDMI on a new Mac Pro. I have the Pro Tools 11 HD Omni system and have not experienced any problems whatsoever. So...I tend to agree...this may be a Macbook Pro specific problem.
Old 07-01-2014, 01:53 PM
JCBigler's Avatar
JCBigler JCBigler is offline
I wonder if this will affect the new Mac Pros, since they use their HDMI output is run off of one of the Thunderbolt ports?
Justice C. Bigler
www.justicebigler.com
Home/mobile: Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Focusrite Red 8Pre / Protools HD Native 2018.10 Ultimate
Old 07-17-2014, 01:47 PM
Hugh-H, to answer your two questions:
1) Holding "N" doesn't help. I still do not get the HDX option in my playback engine. Only disconnecting the HDMI cable seems to solve the issue.
2) After starting HDX successfully, if you were to plug the HDMI cable in, the monitor will blink a few times (almost as if it is mechanically syncing itself) and then display a blank desktop with a dark-greyed out menu bar and no Pro Tools. There would be no icons on the desktop (assuming you had icons before), and there would be no functionality from the mouse. One would assume at this point that the computer had crashed, but simply disconnecting the HDMI cable restores things to normal. Contrast that with plugging in the HDMI cable when HDX is NOT running and it operates as normal, displaying what is on my screen on my external monitor.
Old 07-17-2014, 02:25 PM
Thanks,
Hugh
Old 07-18-2014, 02:45 AM
Emcha_audio's Avatar
Not a mac know-it-all but have you tried to disable the hdmi audio from the mac bios (assume there's one?)
Manny.
#BOYCOTTTUSPRODUCTS
just not Pro tools and compatible plugins...
Old 07-18-2014, 11:10 AM
If the menu bar appears on your external display without the desktop icons it means your MBP is operating it's separate displays as separate "spaces". The last time I checked PT does not like this, don't know if that was ever fixed.
Close PT, go into System Preferences/Mission Control and de-select "Displays have separate Spaces". Then log out and back in. This should enable PT to function normally with multiple displays.
Hugh
Old 07-18-2014, 06:17 PM
Hugh
Good to know... Although this monitor fix doesn't solve the problem of HDX not showing up in the playback engine without first unplugging the HDMI cable. Pro Tools is becoming more and more like a dusty old 8-bit Nintendo cartridge that you have to blow into to make work. I wish I could just turn it on and have it work perfectly every time. *sigh*
Calculating Video offset hdmi external monitor justanotherpostguy Post - Surround - Video 48 12-28-2012 01:31 PM
anyone have any experience with Arvus HDMI-2a HDMI to 8 ch AES Craig F Post - Surround - Video 0 12-17-2012 05:24 PM
Classic Bundle, Found Culprit RBp Digidesign Hardware & Software 4 04-19-2011 04:38 PM
Using HDMI cards with Pro Tools Dode Post - Surround - Video 34 04-22-2010 03:32 AM
Reboot file found as culprit Stone Knife 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-30-2002 06:12 PM
