Old 02-09-2010, 06:35 PM
bearease bearease is offline
Default Xmon Stereo outputs
Measuring the outputs of the Xmon stereo outs, the right side is approx. half the voltage level of the left. I'm sending 1k tone to all 6 "main" inputs at +4 via Pro Tools, then selecting mini (ie. stereo) speakers.
Using a D-Command on a Mac G5 2.7, and PT 8.
Is there an internal adjustment for the St. outputs? Could Firmware upgrade cause/help this? I'm not currently at the stage, so I don't know the current FW version off the top of my head, however it should be the most current.
Thanks for any assistance.
Old 02-09-2010, 09:10 PM
Top Jimmy's Avatar
Default Re: Xmon Stereo outputs
Half the voltage could indicate one side of the balanced connection is lifted.
While diagnosing, keep in mind that the mini outputs are sourced from channels 1 and 5 of the main and surround inputs. Check the output from the interface before it enters the X-Mon to make sure that that the problem isn't occurring there.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.2.
Pro Tools HD 12.8.1, Mbox3, MOTU PCI-424 w/ 2408mkII & 1224 (Mac)
Pro Tools 11.3.2, Mbox2, Focusrite Scarlett 18I8 (Win 7)
Old 02-24-2010, 07:15 PM
Robin_Parnaby Robin_Parnaby is offline
I'd check the cabling first as it sounds like you lost one half of the balanced line.
No sound from XMON cue outputs Calvinc3 Pro Tools 9 Discussion 4 11-28-2017 12:33 PM
Xmon Stereo 4 input? Maskeeper ICON & C|24 3 10-10-2013 04:25 AM
C24 stereo Outputs off the wall ICON & C|24 12 08-13-2008 11:32 PM
Xmon Outputs 98wildcat ICON & C|24 7 08-19-2007 10:59 AM
Hum at XMON´s mini speakers outputs i.celma ICON & C|24 3 12-01-2006 04:27 PM
