Old 09-11-2001, 05:20 AM
Guest
Posts: n/a
Default ADAT sync
I haven't purchased my LE yet. (my new Macs on the way! [img]images/icons/cool.gif[/img]
I have some overdubs I want to do that are on ADAT, and I need to send someone that ADAT back. I imagine that the tracks need to be on the same spot when I dump it back-so it all syncs on there end.
How do I sync my adat to and fro from LE? What gear do I need?
Thanks!
[img]images/icons/confused.gif[/img]
Old 09-11-2001, 06:03 AM
ccstudios ccstudios is offline
Default Re: ADAT sync
you need a JL Cooper datasync 2 there was one on here for 150 bucks awhile back. what they do is convert the sony 9 pin sync from the adat to MTC then you just specify in PT that you want to use MTC from the datasync via OMS as the sync source or something like that. It is fairly accurate freewheel sync that is good for about 3-5 minutes then it may drift if you dont resolve to a clock which in your case should be the adat clock. I havent tried it yet but I imagine you should be able to resolve to the adat clock if you use the datasync as the trigger. Just get the datasync that's all you need and BTW it supports MMC so you can control your adat from PT's as I do.
Old 09-12-2001, 05:28 PM
Chompers Chompers is offline
search this borad for "adat sync" ..
Very mixed reviews of good ADAT sync.
Its not sample acurate EVER. Sometimes its "close enough"
adat sync studiolion Pro Tools TDM Systems (Win) 0 08-28-2003 06:20 PM
o1v.adat PT5.1 OP XTC sync am3 studiobill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-05-2001 05:59 AM
ADAT SYNC AGAIN ! ! ! ! Eric Heil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-07-2000 03:31 PM
Help With ADAT Sync?? BassD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-08-2000 05:22 PM
ADAT->PT->ADAT in sync Will Russell Tips & Tricks 5 11-15-1999 01:24 PM
