Old 12-09-2017, 12:15 PM
Default High Sierra
OS X is the old name for macOS. You download macOS from the Mac App Store. Apple normally gives access to old versions of OS X and macOS in the Mac App store if you have downloaded them before (when they were current), otherwise it is only the currently release (which is High Sierra). You can Apple contact support and try to ask for access to older versions if you really need it. Or wait until stuff is supported or known to work well enough (which may be now) and upgrade to High Sierra or use a recovery partition to reinstall.... or.... all depends on what you are trying to do and why.
None of this is Pro Tools specific, you should be able to Google and find out all you need on getting macOS or OS X installers.
Old 12-09-2017, 12:25 PM
KV626's Avatar
KV626 KV626 is offline
Default Re: High Sierra
El Capitan is the last OS available on the "purchased" tab... While High Sierra can be of course downloaded from the App Store, here's the link for Sierra (go to "Get Sierra from the App Store": https://support.apple.com/en-us/HT208202
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4
Arturia Keylab 88 Presonus Faderport 8 MOTU 896 iPad Air 2 w/ PT Control
NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc
Old 12-10-2017, 12:26 PM
huzzam huzzam is offline
Beware though, that many computers can't install an older version of the OS than the one they shipped with.
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Old 12-18-2017, 12:11 PM
wwerwath wwerwath is offline
Yeah it's pretty doubtful that sierra will be given drivers for the new iMac pro in an update... Also, I'm sure high sierra is technically working with PT 12 I am more worried about the combination of a whole new computer with all new drivers and components AND a new operating system. Sounds like way too much of a headache for me. I'll just wait a few months and see if they come out with a new mac pro.
Old 12-18-2017, 01:49 PM
Chingy Chingy is offline
PT 12.8.1 and 12.8.2 crash consistently after 20-30 min of use on High sierra for me. Is that expected or happening to others?
  #16
Old 12-18-2017, 01:56 PM
I suspect it's not happening or we would hear about it. What exactly happens? What type of crash?
With that kind of general behavior one thing to suspect is plugin memory leaks. What does the macOS Activity Monitor show you for memory usage? esp. the the memory pressure graph? Does it keep getting worse as you use Pro Tools? Try removing all plugins from the plugin folder and trashing prefs and restarting Pro Tools, etc.
  #17
Old 12-19-2017, 04:14 AM
VRW VRW is offline
Running Pro Tools HD12.8.2 (latest update) on High Sierra (latest update) successfully. No noticeable issues so far.
However I've seen that can get problematic with particular plug ins (SSL Duende for example) or other DAWs (Logic 10.3.3)
on the same system.
Pro Tools itself is working well here. As yet.
Cheers.
  #18
Old 12-19-2017, 05:38 AM
Emi's Avatar
Emi Emi is offline
Pro tools 12.8.2 on High Sierra working without problems here. Pretty solid I may say.
My first post here. Hello to all!
  #19
Old 12-19-2017, 06:25 AM
Pingafuego Pingafuego is offline
Avid updated the Pro Tools compatibility document and Pro Tools 12.8.3 is compatible with High Sierra
http://avid.force.com/pkb/articles/e...3-High-Sierra/
Pro Tools
macOS 10.13 (High Sierra) is supported with Pro Tools 12.8.3 and higher (macOS 10.13.2 required). Note that there was no Pro Tools First 12.8.3 release).
  #20
Old 12-19-2017, 06:26 AM
But it seems 12.8.3 is not available to download yet...
Digi003 with High Sierra elmodagansta FireWire & USB Audio Interfaces (Mac) 22 04-18-2020 10:35 PM
S6L AVB with OS X High Sierra brinnbacka VENUE Live Sound Systems 3 10-20-2018 12:52 AM
High Sierra jon9 Eleven Rack 0 11-16-2017 03:35 AM
High Sierra yet? mlavin00 Pro Tools 12 18 11-13-2017 10:09 AM
12.8.2R2 on High Sierra TrentWilliams Pro Tools 12 3 10-21-2017 10:09 PM
