Old 06-24-2013, 03:18 AM
David_Greenwood David_Greenwood is offline
Default Weird C24 LED Display Problem
Hi guys,
I have an issue regarding my C24. When I turned on the console this morning the narrow LED display started showing some "r" symbols through the first half on the console. Bugged out by this I restarted the console thinking this might resolve the issue but again the display is completely unreadable as the track names have been submerged by this sea of "r" symbols.
I have done the following to try to resolve the issue:
- reset the device a couple of times
- did LED and Vegas Mode test (the "r" symbols stay in place)
- Reset firmware
- updated firmware
- connected and disconnected the device via Peripherals - Ethernet controls
I would really appreciate help as I need to resolve this ASAP, so I hope you guys can help me in this issue.
Thank you
Old 06-24-2013, 06:31 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Weird C24 LED Display Problem
In 11? Whats your system?
Old 06-24-2013, 07:22 AM
Hi DetroitT,
My system is PT9HD. Running on OSX.
Thanks for fast replay!
Old 06-24-2013, 10:36 PM
Craig F Craig F is offline
dieing LED PSUs do weird things
that's my first guess
Thank you,
Craig
Old 07-17-2013, 11:33 PM
stratpicker stratpicker is offline
Having same problem. Came on here to see if I was the only one. I updated to PT 11 and that's when problem started. Went through all the different steps you did and still have the problem.
By the way, I've searched hi and low for the correct firmware and I think my main system is right, but I get an error that tells me my update is unsuccessful. When I check my FW it's 8.03, but my faders are back in 7. something land.........any thoughts?
Old 10-24-2014, 12:15 AM
asterix2k10 asterix2k10 is offline
This just happened to me for the first time, it only happened once and since then I've restarted and it's been fine. I got the @ symbol on all the tracks, it was weird.
Old 11-17-2014, 01:14 PM
s.d. finley s.d. finley is online now
on occasion all my scribble strips will be blank. Power cycling the C/24 brings back the scribble strips.
sdf
www.sugarhillstudios713.com
Old 06-25-2017, 03:04 PM
Versami Versami is offline
Hi guys! Did you solve the problem? I have the same thing on 2 displays?
Weird alien crazy incorrect characters display when opening a session - PTLE 8 Growlyman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-18-2009 11:51 AM
Wav file display - really weird paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-23-2007 03:55 PM
Weird waveform display gugu Pro Tools TDM Systems (Mac) 2 12-16-2005 01:44 AM
Audio Regions Display Problem & Grabber Problem markus44uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-25-2002 04:08 AM
Display Problem phattrax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-21-2002 10:17 PM
