Old 06-23-2012, 10:02 PM
epu epu is offline
Default How do I uninstall PT10? No 'Uninstall' option in Control Panel
Why is this so difficult? All versions of PT came with an uninstaller. I do not see one in my program folder, and the only option in the control panel is REPAIR. There is no "Uninstall". I was ready to upgrade to 10.2
How do I uninstall 10 to upgrade to 10.2?
Macbook Pro 15" (Mid 2014)
16GB RAM
512GB SSD
Pro-Tools 12
2.5GHz i7 Quad Core
Old 06-24-2012, 01:57 AM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: How do I uninstall PT10? No 'Uninstall' option in Control Panel
How about add / remove programs ?
Chris
Chris Lambrechts
Applications Specialist- Live Sound
Old 06-24-2012, 06:49 AM
Bill Denton Bill Denton is offline
Seems like there was a thread on this a while back...the solution was to click "repair" and you would then be given an option to "completely remove" (or something similar)...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 06-25-2012, 10:50 AM
TheJamsh TheJamsh is offline
9 times out of 10, it takes a complete reformat to remove Pro Tools from your system. At least, that's my experience of it.
www.anvilaudio.co.uk - PC Users: Buy Skootch, you won't regret it.
PC: Windows 7 64-Bit, ASRock Extreme 4 x79 Mobo, Intel Core i7-3820K @3.6Ghz, Kingston HyperX 16GB Ram, OCZ Vertex 3 64GB SSD, WD Caviar Green 2TB HDD, GeForce 560Ti GPU, SIIG TI Firewire Card, PT Keyboard.
O/B: Focusrite Liquid Saffire 56, Focusrite Liquid Mix 32, Alesis D4 Drum Module, Alesis MIDIVerb4, M-Audio Axiom 49 v2, M-Audio BX8a's, Audix DP7
Old 06-25-2012, 03:37 PM
Go to Uninstall a Program, right-click on PT10 and select repair/modify, then you can choose remove(or uninstall) on the next window. Make sure you select to remove the HD driver as well(especially if you are trying to update to 10.2). Drive imaging is an excellent alternative that I recommend to everyone('scuse me while I jump on my soapbox). Save a drive image of just the OS with all tweaks, another with just Pro Tools(no 3rd party stuff) and a 3rd image with everything. That way, you can get back to a point with a minimum of fuss(and wasted time). I also keep a cloned system drive of my working system drive(so I can recover from a total crash in minutes...actually in seconds since my hard drives are all in tool-less drive cages).
Old 06-26-2012, 07:25 AM
Kirby B. Kirby B. is online now
If Albee's answer does not work, double click the setup .exe and choose uninstall from there.
Windows won't let me uninstall PT10? thyrtien Windows 2 03-06-2013 02:20 PM
now that PT10 is installed, should I uninstall 8 LE? Rotundra Pro Tools 10 3 12-08-2012 08:08 PM
Uninstall PT9 to install PT10 Trial? Legion6789 Pro Tools 10 4 12-19-2011 07:13 PM
no uninstall option adu808 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-20-2008 08:39 AM
Windows Media Player 9 (no uninstall option!) 3inacipher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-27-2003 08:25 AM
