Old 11-21-2010, 11:51 AM
Default Re: Why is there no playlist view for midi?
I'm sure this is on the books to be implemented... I'd personally like them to extend it to not only being able to expand to view playlists, but a method to expand a MIDI Track which would show each note on a separate Playlist.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 11-21-2010, 12:20 PM
meech meech is offline
Rail
That would also be a welcome feature! I occasionally have to do this manually and it can be time consuming with a lot of notes.
Old 11-22-2010, 06:35 AM
daeron80 daeron80 is offline
Not for each individual played note, obviously, but for each MIDI note number? That would be OK for drum/perc tracks, provided that there were an option to play all playlists at once.
I can't think of any relevance to tonal instruments. But a related concept might work. We've long been able to split by highest note/lowest note. It's never perfect, and can't be, but if it could be done automatically into playlists (that all played at once) and you could then click-n-drag notes from list to list with a flick of the wrist, that could tidy up the operation neatly. Much more efficient than select-cut-moveUp/Down-paste.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 11-23-2010, 10:16 AM
Obviously. Yes, it can be done now, but my idea would streamline the process.
Rail
Platinum Samples
Old 06-16-2011, 10:23 AM
rab523 rab523 is offline
Any word on this? I am also using Superior Drummer 2 to track midi and would love to be able to use playlist view. Software instruments need to have the same features as audio tracks.
  #16
Old 07-19-2011, 12:44 AM
matthias.matthias matthias.matthias is offline
I'm all for this feature! Did you vote in the ideascale already? If not, please do.
http://protools.ideascale.com/a/dtd/...DI-/30551-3779
http://protools.ideascale.com/a/dtd/...ts./13542-3779
http://protools.ideascale.com/a/dtd/...ing/19984-3779
They are basically all asking for the same thing. Would be nice if they could be consolidated into one.
FR: MIDI Playlist View
  #17
Old 07-19-2011, 02:46 AM
midnightrambler midnightrambler is offline
Just use a few MIDI tracks routed to the same instrument, comp onto main track, then hide the MIDI tracks. Which is more or less exactly the same thing as seeing/hiding playlists.
Honestly, you lot'd moan if ProTools gave you free backrubs.
  #18
Old 07-19-2011, 06:06 AM
But then the third-party back rub plug-in manufacturers would pitch a fit.
Seriously, though. Playlists are the best idea since sliced waveforms. Having MIDI tracks work as described in this thread would turbo-charge workflows. I suppose we could keep riding horses to work and demean people who drive cars, too, but...
David J. Finnamore
  #19
Old 07-21-2011, 05:55 AM
brianjanthony's Avatar
brianjanthony brianjanthony is offline
I use Reaper to split drum tracks into playlists. In Reaper, drag in your drum midi track (something a client might have done in Addictive drums, EZdrummer,etc). Right click and separate each note into tracks. Re-export the Midi and import into pro tools. It takes like a minute tops. I hate to need external DAWS as work arounds, but this one rocks.
In Reaper too, I usually load up Addictive Drums or Superior and export those individuals as audio files as well, in case I need/want a timing reference.
Brian
www.brianjanthony.com
MacPro 6 core 3.46 Cheese Grater
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
TDM user way back. PT user since 98.
I'm either working, sick, or both.
  #20
Old 07-21-2011, 10:49 AM
Pro Tools has the ability to split a MIDI Track into separate tracks... no need to switch apps for that... and that has nothing to do with playlists.
I would like an option in Pro Tools though where you could hit a caret on a MIDI Track and it puts (displays) each note on a separate track for editing, then hit the caret again and the track reverts to a single MIDI Track.
Rail
Platinum Samples
Pro Tools 8 Midi Playlist View joe_04_04 Pro Tools M-Powered (Mac) 2 10-10-2011 07:10 AM
Editting Midi Takes in a Playlist View? asounds Pro Tools 9 2 09-12-2011 12:06 AM
Bug in playlist view mrjohn Pro Tools TDM Systems (Mac) 1 01-28-2010 10:45 AM
Why not Midi Playlist View? Dizzi45Z Pro Tools TDM Systems (Mac) 13 07-04-2009 10:25 PM
PT8 - No Playlist View for MIDI Tracks? weezerboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-23-2008 07:48 PM
