configuring 2nd harddrive for audio?
Hi there,
I have a PIII 1GHZ PC (old I know) with a 2nd harddrive for audio. I have a just bought an MBox and tried to configure the 2nd harddrive for DMA in device manager as per Getting started manual. However, it won’t allow me to select DMA it selects PIO only. The system drive is o.k. So when I try to record on the audio drive, protocols LE 6.4 stops it and tells me to adjust the buffer size. No matter what size I set it it doesn’t record. However, if I record on the system harddrive it records perfectly, no problems at all. So I figure maybe the jumper setting on the audio harddrive is not set properly or something else? It should operate under DMA. Any help much appreciated! |
Re: configuring 2nd harddrive for audio?
Hello dubs,
You'll need to give us more info on that second drive... Type, rotational speed, what controller is connected to... good luck,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Cavell Studios |
Yes! Thanks Chris I think that was the issue as it use to run on DMA.
I'll give it a go and let you know how I get on! What would I do without you tech dudes?! |
configuring midi/audio inputs | therecordinghouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-04-2006 05:27 AM |
configuring ibook to use mbox as audio out | jpf99 | General Discussion | 3 | 02-21-2006 05:58 AM |
Configuring multiple audio hard drives | Carl Fuehrer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-01-2005 02:44 PM |
Configuring audio drives | Carl Fuehrer | Pro Tools TDM Systems (Win) | 4 | 01-01-2005 12:12 PM |
Configuring Audio/Midi in 6.0- problems | SBlane | MIDI | 1 | 07-04-2003 12:02 AM |
