Old 10-05-2007, 10:59 PM
GtrDude GtrDude is offline
Default How to bypass the mic pres and the AD converters - 003
How do I bypass the mic pres and the AD converters in the 003?
__________________________________________________ ______________
I'm using a good mic pre that goes via XLR's into a Lynx Aurora 8.
But then must I come out with XLR's going into channel's 5-8 in the back of the 003?
Or do I go into the Optical In?
Or do I go into the SPDIF?
My objective is to completely bypass the Mic Pre and the AD Converters in the 003.
Thanks
GD
Old 10-06-2007, 02:55 AM
Aussie169 Aussie169 is offline
Default Re: How to bypass the mic pres and the AD converters - 003
By using an external ADAT or S/Pdif converter box
Old 10-06-2007, 11:16 AM
cherryrecording cherryrecording is offline
If your Aurora has the optional ADAT card, just use an optical cable between it and the 003. If it doesn't, get one. Set Pro Tools to take word clock from ADAT optical, make sure the Auroras' sample rate matches your session, and you're good to go.
Omni Pres/Converters vs. Other Pres/Converters Infiltrator Pro Tools HDX & HD Native Systems (Mac) 1 01-15-2012 11:28 PM
No Bypass of mic pres on the Mbox2??????? Humongous 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-06-2006 12:15 PM
How do I bypass 001 mic pres jetboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-20-2004 12:33 AM
Can you bypass the 4 pres on the 002R? spicyitaliano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-31-2003 12:41 PM
Bypass digi001 mic pres thru XLR inputs? trew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-02-2002 08:25 PM
