PT 002 Rack SPDIF not seeing Rosetta 200?
Hi everyone,
I use an Apogee Rosetta 200 for A/D with my 002 Rack via SPDIF. It works fine when I do sessions in 44.1 or 48, but when I'm in 88.2 or 96, I get "Input Path Not Available". Is there something I'm doing wrong? I'm using PT 7.4cs7 with 002R, Mac OS 10.4.11 G5 Dual 2.5mHz PowerPC. Any suggestions? thanks, Joe |
Re: PT 002 Rack SPDIF not seeing Rosetta 200?
You are using the RCA type digital connectors, correct? I'm not sure if the 002 accepts those sample rates on the Toslink (squarish) type connectors usually reserved for ADAT type inputs. I could be wrong though. What inputs are assigned in your I/O?
Not at home with system right now, but if no one has answered by the time I get home CST, I'll try the other connector (toslink) and see what sample rates I get as well.
*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~* -Mac Pro -10GB Ram -Digi002 -ProTools 9 -OS 10.5.x |
spdif via rca and aes go up to 192k
spdif via lightpipe is limited to 96k of course these are all limited to 96k by the 002 itself. |
I am using SPDIF with a RCA cable from the Rosetta to the 002R SPDIF in. The setup works fine for 44.1 and 48k sessions, so I'm not sure what's up.
Have you verified in Setups>IO Setups that the SPDIF paths are available when you're in a 96k session?
Thanks. I didn't know I had to manually activate the spdif when switching the sampling rate. It seems to be working now.
cant record and receive digital data via spdif from rosetta 200 to | bigpapajk | Pro Tools 9 | 0 | 10-24-2012 06:03 AM |
003 spdif rosetta 200 connection issue! | bigpapajk | General Discussion | 0 | 10-24-2012 05:55 AM |
003 rack with rosetta 800 | bigdrum2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-11-2008 04:10 PM |
Rosetta FW to Logic or SPDIF to 002r? | jazg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-27-2006 01:50 AM |
002 Rack v Rosetta 200 | Everything | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-05-2004 09:54 PM |
