Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 04-25-2020, 05:35 PM
awritersparadise awritersparadise is offline
Default After Win Update - PT hardware is either not installed or used by another program
Using Pro tools with Apollo UAD quad firewire . Win 10 - working fine forever... then windows did an update last August.. and immediately upon reboot.. I get "Pro Tools hardware is either not installed or used by another program"..
Tried a bunch of things to no avail, so I uninstalled Windows Updates...and it starts back working fine. but windows forces an update every 30 day no matter what.
Same problem... repeat... uninstall... 30 days... repeat.. uninstall.
I shouldn't have to roll back my computer every month to August of 2019 to get it to work with Pro tools..
Everything else I have is up to date.. always is.. latest drivers..
Things I've tried:
- Check Ilok. same prob
- trashed prefs. same prob
- update to the latest PT driver ... same prob
- I Set Windows so it uses the Apollo for system sounds and see if that works okay. If it does then the Apollo itself is okay - so it's not Apollo.
I can't be the only one with this problem?
Appreciate any help you can give.
Thank you!
Stacy
Custom Thermaltake PC / Windows 10 / 16 gigs of ram / Intel I-9 CPU (12 cores) / UAD Apollo Quad Firewire Interface / M.2 System Drive / 5TB Solid State Session Drive / Pro Tools 2019 Subscription
Old 04-25-2020, 10:01 PM
Southsidemusic's Avatar
Default Re: After Win Update - PT hardware is either not installed or used by another progra
As this is a Microsoft and UA issue you will get better info on UA’s foums as there are many users with that same problem there. Maybe someone can give some pointers but here I doubt anyone can do much for you TBH.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 04-26-2020, 10:04 AM
EGS's Avatar
EGS EGS is offline
Don't assign Windows system sound to the Apollo.
Click for audio/video demo
Click for resume
Old 04-26-2020, 10:14 AM
The Weed's Avatar
The Weed The Weed is offline
And if you have W10 Pro, use Group Policy to turn off Windows Update.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Pro Tools hardware is either not installed or in use by another program binaural42 Pro Tools 10 8 11-25-2015 10:54 AM
Pro Tools hardware is either not installed or used by another program kristiankristian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 03-27-2014 07:19 PM
Pro Tools Hardware is either not installed or in use by another program f.judice Windows 6 04-05-2012 08:33 AM
'Pro Tools hardware is either not installed or used by another program' thedeeviant1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-19-2009 03:01 PM
Pro Tools hardware is either not installed or used by another program kristiankristian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-06-2008 09:54 AM
