Old 01-03-2003, 01:15 PM
Roy Howell Roy Howell is offline
Default Switching an internal HD(with sessions on it) from one pc to another....
Thanks for any advice on this...
There is a 40gb Western Digital internal HardDrive(with sessions on it) on another pc here, and I want to put it in MY pc, which has a 20gb Sys. drive, but no other INTernal drive. It does however, have a 1394 Ext. Firewire Drive.
My question is, do I have to do anything other than hook it up? (like clear it out, format it, start from scratch...?) I just want to be sure.
Thanks, Roy
rh music
Old 01-03-2003, 02:42 PM
da BaSsTaRd! da BaSsTaRd! is offline
Default Re: Switching an internal HD(with sessions on it) from one pc to another....
the only thing you need to do is make sure the jumper settings are correct. you can decide whether to format or partition later based on what is your anticipated use.
i love my apple iPhone!
Old 01-03-2003, 03:03 PM
Thanks Brian... but, I'm still not quite sure about it. I mean, when I got the HD, I set the jumper position correctly at the time. But, would they change just because I'm switching pc's? I mean, the HD is running right now, on the old Compaq (you remember, my old one). I was hoping to just pull it out, and just install it in my new pc here. Thanks, Roy
rh music
Old 01-03-2003, 03:57 PM
mjames08 mjames08 is offline
Roy-
Was the HD a second drive in the computer you are taking it from? If so, you probobly won't need to change the settings [img]images/icons/smile.gif[/img]
Old 01-03-2003, 04:37 PM
J. FO J. FO is offline
jumper settings=master or slave. the HD with the OS needs to be set to master and the additional HD needs to be a slave. most HD's even say master or slave next to the jumper pins you need to have connected. get a flashlight and see for yourself.
Jeremy Forbis
Old 01-03-2003, 04:55 PM
Thanks you guys... The HD I want to put in is set up as a Slave drive, so that's great. I had set it up myself(I had forgotten the slave/master thing). Both pc's in question already have a Master 'OS'/System drive. So, it sounds like I can just take it from one pc, and put it in another safely. That's great....... Thanks very much... [img]images/icons/smile.gif[/img] -Roy
rh music
Old 01-03-2003, 05:10 PM
bi0force1 bi0force1 is offline
speaking of master and slaves....where did captian pants go? its time he start swabbin' the decks [img]images/icons/grin.gif[/img]
Old 01-03-2003, 06:19 PM
Indeed, where is the Captain of the High Seas tonight?... he seems curiously absent lately. Must be below deck on his ProTools again...
rh music
Old 01-03-2003, 07:36 PM
i think he below deck polishin' up that ole wooden leg of his if you knw what i mean [img]images/icons/smile.gif[/img] .....arrrr, thar she blows [img]images/icons/grin.gif[/img]
Old 01-03-2003, 08:06 PM
[img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img] I am laughin....that's so funny... [img]images/icons/grin.gif[/img]
rh music
losing tracks when switching between sessions Tommy Dunbar Pro Tools TDM Systems (Mac) 0 03-21-2012 12:13 AM
sessions and plugins deleted after switching users hillelkaps Pro Tools M-Powered (Win) 0 06-07-2010 11:22 PM
switching sessions - delay on playback? dopplah Post - Surround - Video 0 05-20-2009 06:37 AM
6.9.2 Crashes When Switching Sessions ronstephens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-18-2005 10:14 AM
6.9.2 Crashes When Switching Sessions ronstephens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-18-2005 10:10 AM
