Old 03-16-2020, 08:12 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: CPU spike and errors on PT Ultimate/HDX system
Which version? Melodyne4 here without a hiccup
Janne
Old 03-16-2020, 12:22 PM
the.engineer the.engineer is offline
Latest 4.2.4
Just running an 8 track recording session. Been going 110 minutes now, buffer on 512.
Could just be a weird thing in my system.
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Pro 5,1 (Mid 2010) | 3.46GHz Six-Core Intel Xeon | 32GB Ram | AMD Radeon RX 580 8GB | Apple 27" LED Cinema | 500GB Samsung 960 EVO M.2 SSD System Drive | 1TB WDC Sample Drive | 512GB Samsung SSD Audio Drive (temporary) | UAD-2 Quad PCIe
Mojave 10.14.6 | Pro Tools Ultimate 2019.12 | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
Old 03-16-2020, 03:46 PM
smokeydan smokeydan is offline
We have Melodyne 4 installed, present on some sessions I tested today, not present on others. It did not appear to make any difference, once I had frozen audio tracks which had Altiverb instances, all sessions were able to run on the lowest buffer size for 20 mins or more with no errors or CPU spikes.
Mac Pro 5,1, 2 x 3.46Ghz six core Xeon, 64GB RAM, High Sierra, PT Ultimate 2019.12, H/D Native PCie, Omni interface.
Mac Pro 6,1 12 core, 64GB RAM, High Sierra, PT Ultimate 2019.12, 2xHDX cards in Sonnet TB Chassis, 2 x Lynx Aurora 16 interfaces.
MacBook Pro 32GB RAM Catalina, PT 2020.3, non-functioning MBox 3 Pro
Old 03-18-2020, 10:02 AM
I don’t think it’s melodyne anymore.
Really hard to nail down what’s actually causing the 9093 error. I can’t reproduce it and I don’t have time to put my plugins back one by one.
I have disabled spindump and carrying on.
James Welch
Old 03-19-2020, 02:41 PM
So my 4TB Raid 0 7200rpm spinners took a dump on me last night. Switched over to an SSD for now. Everything is blazing fast.
I think the one of the disks in the Raid array was failing and taking everything else with it.
To be continued...
James Welch
  #16
Old 03-19-2020, 09:06 PM
JFreak's Avatar
Yep -- that is the problem with RAID 0 that stripes for performance without parity information, so it has zero fault tolerance. Good riddance, SSD storage is so blazing fast now.
Janne
  #17
Old 03-20-2020, 03:37 AM
Will Russell's Avatar
Will Russell Will Russell is offline
I work almost exclusively at 96k on my 5,1 MacPro HDX system and I have identified Sonarworks, Autotune, Soothe and Gullfoss as leading causes of CPU spikes at low buffer settings. Sonarworks is by far the worst. By far. I can have one single stereo master track in a session and it spikes at a buffer of less than 512.
FWIW I have not identified Altiverb as a source of spikes on my system.
Will Russell
Electric Wilburland Studio
www.wilburland.com
12 core 3.06Ghz MacPro, OS 10.14.5, PT2020.5, HDX, D-Command
Retina 5k iMac OS 10.14.5, PT2020.5, MBox3
Retina MacBook Pro OS 10.15.6, PT2020.5
  #18
Old 03-20-2020, 05:47 AM
Hey Will, that's really interesting. I used to have Sonarworks running on my master output but got so annoyed having to constantly turn it on/off (I would forget a lot of the time!) that I now have a dedicated Mac Mini running Sonarworks with a UA Twin running between my monitor controller and speakers.
Perhaps not the best converters but makes my life a whole bunch easier.
Thankfully I'm yet to experience the Mac Mini to have a crash and for the speakers to output full scale noise. I should probably build in a fail safe for that...
James Welch
  #19
Old 03-20-2020, 03:01 PM
Guys,
I think I may have cracked this...
Mixing all day, different sessions, 128 buffer(!), session data importing, bouncing, recording, you name it.
Not a single error...
James Welch
  #20
Old 03-20-2020, 03:58 PM
arche3's Avatar
arche3 arche3 is offline
Originally Posted by the.engineer View Post
Guys,
The drive error then making the crashes right?
Sent from my SM-G986U using Tapatalk
A TON of spike and errors with 12.8 9093/72 pqlior@mac.com Pro Tools 12 38 06-29-2017 02:54 PM
Buffer Errors (6086 and 9128) using Komplete 9 Ultimate Instruments dunnaj Virtual Instruments 0 05-29-2013 12:14 PM
Windows 7 Ultimate Freezing and BSOD Errors! terrencej31 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-13-2012 05:05 AM
Processor spike & system freeze-up is sessions psalmeister 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 04-25-2010 04:40 AM
Multiple blue screen errors when trying to install/run PT 8.03 in Windows 7 Ultimate WorshiperDj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-14-2010 02:50 PM
