Old 04-06-2011, 02:44 PM
Blickerding Blickerding is offline
Default PT 9 setup problem..Where are the MIDI IN options in setup menu??
I recently installed PT9 (9.0) on a new built PC. Im using a Tascam DM3200 interface with the firewire card (all latest drivers/firmware for both from Tascam site) In the setup menu in ProTools, under peripherals, midi controllers, I put in "HUI" under type. Under 'MIDI IN', my only option is "none", meaning PT is not seeing any midi ( i guess). Under 'MIDI OUT' I am given several options and under '# OF CHANNELS' i get "8".
Can some one answer why I do not get any options under the 'MIDI IN' and more importantly, HOW do I get the proper channels listed. I checked the Tascam forums and saw what settings work but I don't have the option to chose the MIDI IN. (channels 5 and 6)
I'm hoping this is the last 'fix' to get the sytem up and running with PT9.
Thanks in advance for the help.. BLICKERDING
Win 7 Ultimate 64 bit
AsRock Extreme6 MoBo
Evga GeForce 470 Nvidia graphics
12 Gb 1333 ram
120 SSD for sys/programs
2- 2Tb 7200 rpm Hitachi HDDs
Intel i7 3.2Ghz processor
Tascam DM3200 (the only digital item in the setup)
MIDI SETUP takes long to SETUP and doesnt SETUP DartagnanSosa87 MIDI 3 01-28-2013 12:02 PM
Problem with MIDI-what are the different options in setup? lupodwdm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-20-2011 11:27 PM
midi device not listed in setup/peripheral menu larsendiese 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-07-2008 12:17 AM
"Edit MIDI Setup" Setup Menu Item is Missing! altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-08-2004 12:24 PM
setup menu has no edit midi option? help? samrisio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 09-07-2004 01:28 PM
