Old 11-06-2009, 03:58 AM
SonicPete SonicPete is offline
Default Display timecode counter via "video out Firewire"
Is there a way to display my timecode counter via my Video out Firewire (using Mojo)?
I occasionally work with QTs without any timecode burned in and I need to display the TC counter to voiceover artists. Is it possible to get the "Big Counter" to show up through my Video Firewire out?
Pro tools 7.4 HD
192 interface
SYNC interface
Mojo
Any help is much appreciated!
Thanks
Peter
Old 11-06-2009, 04:08 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Display timecode counter via "video out Firewire"
don't know about the firewire output, but if you have a 2nd monitor for the artist, then you can output big counter on that monitor instead of the main monitor. not what you asked, but a good workaround nevertheless...
Janne
Old 11-06-2009, 04:13 AM
Originally Posted by SonicPete View Post
Pro tools 7.4 HD
192 interface
SYNC interface
Mojo
Thanks
Peter
Not possible with a mojo but with the video running on a DVI-out. But the sync has a TC-burn-in feature when you route the composit-signal through it. Check the sync i/o manual for how to set this up.
frank.
PTHDn 2020.9 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 11-06-2009, 05:24 AM
Great, will check the SYNC manual.
Thanks for your help guys! Much appreciated!
/Peter
Old 11-06-2009, 09:35 AM
kptkarl kptkarl is offline
Insert Time Code text
Old 11-06-2009, 10:20 AM
Sonny Keyes Sonny Keyes is offline
Originally Posted by kptkarl View Post
Fantastic! Thanks!
Sonny Keyes
Ricochet Audio
Toronto
Old 11-06-2009, 11:05 AM
FajitaTone FajitaTone is offline
composite out of mojo to video in of Sync, video out of sync to TV video in.
Enable burn-in window in sync prefs
select generate TC, put PT online
you now have burn in on the display and not permanently in the movie.
Ray Trujillo
Freelance Audio Engineer
Old 11-06-2009, 11:21 AM
Fantastic, thanks!
Prblm with " video out firewire" function on w7 and PT10 maquisar Post - Surround - Video 6 05-15-2012 09:33 AM
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init bcrichguitar macOS 3 04-01-2012 09:10 AM
Main counter mode not switching using "counter" switch bashville ICON & C|24 2 08-07-2009 04:07 PM
New FREE Pluggo - Timecode Counter Display jkaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-31-2002 06:20 AM
Feature Request: "Show Markers" in Big Counter Display s2n Pro Tools TDM Systems (Mac) 1 12-21-2001 10:02 AM
