Old 02-08-2009, 07:40 AM
Slerker Slerker is offline
Default Switching subwoofer from "discrete mode" to "stereo mode"?
Hi all!
Asking perhaps a novice question here, but I'm pretty new to audio post so bear with me. I've been mixing in surround at a facility for the last few weeks, and all has gone well. The outputs of the interface go via a Multimax EX controller to a Genelec 5.1 monitor system.
Now, I am asked to do a stereo project on the same system, and I am uncertain on how to deal with the bass management. I understand that in a stereo project I have no discrete subwoofer, but I would like the subwoofer to take care of all frequencies below a set cutoff, in order to mimic what people watching with a home cinema system would experience, right? (or wrong, I'm on thin ice here)
Since the subwoofer of the Genelec system is linked to an output on the interface (output 4 in my case, as it is wired in a LRCLfeLrRs configuration), running stereo material on the system bypasses the subwoofer entirely. How do I go about changing so that the subwoofer stops acting as a discrete speaker, and kicks in as a bass enhancer for my stereo material? Do I change a setting on the Genelecs? Or in the Multimax setup? Or do I even want to change anything at all?
Your help and patience is much appreciated,
/Eric
Old 02-08-2009, 06:51 PM
AudioPostChris AudioPostChris is offline
Default Re: Switching subwoofer from "discrete mode" to "stereo mode"?
Your subwoofer on your Genelecs may have bass management built into it with a crossoever filter , my Adams sub12 does. If not you'll need bass management controller (something like blue sky mkII ).
So many people have small speakers with subs, that I think it's a good idea to reference your mixes with this type of system "bass managed" but you must make sure you properly calibrate the sub and the satellites at the same volume.
Old 02-09-2009, 11:14 AM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
If you're running the outputs of your controller THROUGH the Genelec sub, then it will handle all bass management of 5.1 and Stereo material.
Which system/sub are you using?
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 02-09-2009, 12:08 PM
Thanks guys.
I'm running 8040A Genelecs with a 7070A sub, all going through the sub. And actually, upon closer inspection, I do have output from the sub in stereo operation. It's just significantly lower.
Which of course leads me to question if this is normal. If I play content that is to be reproduced only via the subwoofer (i.e. a sound containing no information over 85Hz), it will sound substantially louder if I output it directly to the subwoofer compared to just playing it "in stereo" and letting the bass management redirect the signal. In my world, they ought to sound equally loud, but this is clearly not the case. So, am I still doing something wrong, or is it the setup?
Thanks again,
Eric
Old 02-10-2009, 07:52 PM
Genelec has great setup docs for the 7070. Have you taken a good look at them? If you're only running STEREO through the 7070 you won't have the option to send specific LFE information, only with 5.1 do you get that. If you've setup the system correctly, bass management should be correct, i.e. an extra octave of bass compared to without.
We're running the 8240s (with DSP) in several rooms and love the way they automatically setup with the GLM software. A real time saver.
Old 02-11-2009, 04:49 AM
Thanks Eric.
I do recognize that running in stereo will not let me output to the subwoofer directly. However, if I play a sound that has no content above the crossover frequency for the bass management, it should be taken care of solely by the sub, right? And in that specific case, playing the file should sound identically whether I'm playing through my stereo output or outputting it directly to the subwoofer, shouldn't it? That is clearly not the case here, there's at least a 9dB difference from what I can tell. The room has been calibrated by a representative from Genelec, so I'm hesitant to believe that there is anything wrong with the setup, but something is strange for sure.
/Eric
Old 02-11-2009, 07:04 PM
I'm confused when you say:
If you're wired correctly you should ALWAYS be playing through the sub since it handles the bass management.
Can you specify exactly how you have things hooked up?
__________________________________
I just re-read your original post. What do you mean by:
As well as:
It sounds like you have a feed going to the LFE input as well. Unless you're actually mixing with a separate LFE channel, there shouldn't be anything in that input on the sub. Also note that the LFE channel probably has the +10dB switch active, which is correct for a room doing Dolby specific encoding. This boosts anything on the LFE input by that much!! Is this what you're doing and hearing?
More info, please.
HTML code is On
i have a problem with "Pencil Tool". Why it's always in "square mode" ? ak11_lin macOS 6 08-25-2013 05:38 AM
Kana-mode" Japanese mode ", the region gets cut off edamame_zombie Pro Tools 9 1 08-07-2011 09:24 PM
Switching a HD from "transfer only" to "record mode" BretFarewell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-16-2010 12:49 PM
Main counter mode not switching using "counter" switch bashville ICON & C|24 2 08-07-2009 04:07 PM
So Where is this ""WIN2K COMPATABILITY MODE""?? el matador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-23-2002 03:30 PM
