Old 10-29-2002, 08:22 PM
LATablette LATablette is offline
Default Help!! trying to setup PT 5.3.1
ok, I downloaded the upgrade of 5.3.1 to my windows xp pc. when I try to open the file that was downloaded, I get a message saying the file cannot be opened without knowing what program created the file. The file has a .cfm extention but I don't know what that means. I can't see a .exe file. any help would be greatly appreciated.
Old 10-29-2002, 10:51 PM
Shamtown Shamtown is offline
Default Re: Help!! trying to setup PT 5.3.1
.cfm? do use a download accelerator like gozilla or get-right or something? if you downloaded the correct file it should end with .exe
Sean
Old 10-30-2002, 01:46 PM
The Electric Trombone The Electric Trombone is offline
Agreed, you might want to re-download the file and see if you get differetn results.
Do you have broad-band of any sort ?
regards,
Dan Atkins
The Electric Trombone Studio
Old 10-30-2002, 05:49 PM
turns out it was an exe file, but for some reason it had that different extention. When I renamed it with an exe extention, it worked fine. go figure.
MIDI SETUP takes long to SETUP and doesnt SETUP DartagnanSosa87 MIDI 3 01-28-2013 12:02 PM
I/0 setup weirdness, sessions overwrite my setup digidesigner Pro Tools TDM Systems (Win) 0 10-20-2011 11:40 AM
PT 9 setup problem..Where are the MIDI IN options in setup menu?? Blickerding Windows 0 04-06-2011 02:44 PM
"Edit MIDI Setup" Setup Menu Item is Missing! altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-08-2004 12:24 PM
OMS Setup: Interface Req'd? Setup referrences? eltornado 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-19-2000 04:17 PM
