CANNOT HEAR THE "PREVIEW"OF AUDIOSUITE PLUG-INS
When I try to preview an audiosuite effect, before applying it I hear nothing, is there a setting I am missing?
Thanks, Kingsta [img]images/icons/smile.gif[/img] |
Re: CANNOT HEAR THE "PREVIEW"OF AUDIOSUITE PLUG-INS
I believe with most Audiosuite plug ins you have to select some audio data, so the Audiosuite plug in can preview it.
Go to a track, select a portion of the audio and then try the preview button. This gives you a chance to audition a few areas of the track before committing to processing the tracks. Hope this helps, Dave Patterson Knobville |
HEy Dave thanks for the reply, the problem exists even though I have selected a portion of a track...strange, any ideas?
Kingsta |
Administrator Avid Pro Audio Community |
Check where the output for your previewing is set in the hardware i/o set-up box.
Just to expand on Burton's post:
-AudioSuite plug-ins preview using the output(s) selected in the Audition menu (Setups>I/O Setups window). Assuming you monitors are connected to the Monitor Outputs of the Digi001 (or you are trying to preview from the Headphone output), make sure “Out 1-2 (Stereo) is selected. Brent |
Yes, and if you have an external converter, then set the "Audition Options" in the I/O Setup to match your "new" main outputs (optical 1/2 for me).
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
"Vari-fi Plug-in Audiosuite doesn't work" | D.Taylor | Windows | 0 | 10-18-2012 06:55 AM |
Import session data... please break out "plug in settings" and "plug in automation" | yeloocevad | Pro Tools TDM Systems (Mac) | 19 | 10-05-2011 01:04 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
Can we get a keyboard shortcut for "PROCESS" in an audiosuite plug-in??? | pshammond | Tips & Tricks | 0 | 09-24-2010 11:57 PM |
DAE error 7450 during Audiosuite "preview" | gruntmaster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-19-2009 04:25 PM |
