convert routing folder back to aux track
is there a way convert routing folder back to normal aux track ?
sorry for the dump question, just can't figure out what to do... |
Re: convert routing folder back to aux track
Not that I'm aware of - you'd just have to create a new Aux track with the same I/O. You could drag plugins and sends back to the Aux track.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
In Pro Tools, you can't convert a Track to a different Track Type (i.e., Folder to Aux).
In that particular situation, you have the following option: Select all the Tracks in that Routing Folder, right-click on one of the highlighted Nameplates and from the Contextual Menu select "Move To > Top Level". This takes the Member Tracks out of the Routing Folder hierarchy. But this is just a cosmetic step (organizational). Their outputs are still routed to the Routing Folder Track. You can do the same manually by dragging the Tracks out of the Routing Folder Track. (see screenshot attachment below) Now hold down sh+opt key and click on the Output Selector of one of the (still selected) Tracks and choose New Track from the Output Menu (or any existing Bus from the bus submenu) to route them to a new Aux Input Track as an Audio SubGroup. The Routing Folder still remains in your Session, so you can delete it or "repurpose" it. Be careful. When you re-route the Member Tracks before taking them out of the Routing Folder Track, then you end up with a very confusing routing/organization configuration, where you have an Aux Input Track inside the Routing Folder but the Routing Folder Track now only functions as an organizational tool. I explain all those detailed grouping/routing options in the "Groups" chapter of my new book "Pro Tools 2020 - How it Works". It happens that this "Groups" chapter is available for free (pdf, Kindle, iBook). Just check the link in the signature below.
Edgar Rothermich Author of "Pro Tools 2020 - How it Works" from the Graphically Enhanced Manuals (GEM) series http://DingDingMusic.com/ YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/ |
For the most part true, but you CAN convert an Aux to a Routing Folder by right clicking on an Aux and selecting Convert Aux to Routing Folder. However, you cannot currently convert a Routing Folder back to an Aux, unless you open the session in an older version of PT that doesn't have folders.
Scott Gatteño |
One thing Avid forgot about that command. There is no option to move all the corresponding Tracks (that are currently routed to that Input) into that newly converted Routing Folder Track. You have to do that manually in an extra step (drag over or use the "Move To >" command in the Contextual Menu on the Nameplate.
Duplicate the routing folder's Subgroup aux, then delete it - the duplicated aux will behave like a regular aux.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
brilliant!
Will Russell Electric Wilburland Studio https://linktr.ee/wilburland M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS |
This begs the question: why do the conversion?
I think I could have just moved the contents of the routing folder track out of the folder and back to the top. The problem I was having was that the routing folder, when hidden, also hid the contents.
Yes, but I think the whole idea is for track management in large sessions, so bunches of tracks can be hidden and reopened when needed. You can just close the folder without hiding it. If you need the tracks to show all the time, then maybe you don't need folders.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Serious Routing Folder Bug! | DrewHarrison | Pro Tools 2020 | 8 | 07-21-2021 02:26 PM |
Routing folder+VCA | mgoorevich | Post - Surround - Video | 12 | 09-30-2020 03:45 PM |
Another Folder Track bug: Soloing a Routing Folder doesn't solo routing bus | XJENSEN | Pro Tools 2020 | 7 | 04-24-2020 07:29 AM |
Convert Session's Audio Folder from SoundDesigner II | Dizzi45Z | Pro Tools TDM Systems (Mac) | 3 | 03-21-2011 10:19 PM |
Back up system folder on back up drive? | Mick F. Cantarella | Pro Tools TDM Systems (Mac) | 1 | 12-24-2002 09:15 AM |
