Error -9105 while opening sessions
Hey all. I'm getting a strange error when opening sessions and it seems to happen at random. I will click to open the session and it will give me this error a few times in a row and then opens fine after a few tries. I've done all the usual pref clearing and maintenance.
"Could not complete your request because (-9105) while translating Tracks" Anyone have any ideas what this is? Only thing I can think of is that the AAFs I am getting have both 16 bit and 24 bit files so maybe its a mixed format thing? Pro Tools 11.2.2 HDX2 with OMNI Mac Pro 5,1 Dual 12 core. 40 Gb RAM OS 10.8.5 |
Re: Error -9105 while opening sessions
Does this happen if you hold the shift key while opening the session?
Hi Jonathan. Thanks for the reply. That is the command to inactivate plugins right? I have not tried that, will do. It seems to happen much more when I am switching between sessions on a regular basis throughout the day.
Today I opened up only a few and I didn't get the error. I also cleared out all MXF audio media that had been imported from AAF's and re-imported with force convert to .wav enabled in the import dialog. |
Hi there, I´m getting the same Error when switching session on a regular base.
Anyone ?
PT 11.3.1 HDX2 OSX 10.9.5 Mac Pro 2x2,66GHz 6 Core Xeon / 32GB RAM / D-Command |
I had this problem and found a solution:
- Right click on session icon in finder and select "open with protools" . But always with protools running as a active application in top (not in background or finder selected)
Pro Tools HDX 2018.12 / MacPro 5,1 2x3.46GHz 64Gb ram / Pro Tools HDX / HD I/O 8x8x8 / Omni I/O |
Hi andrum,
Thanks, that sounds interesting. Any idea why this actually works or what´s the difference ? I´ll definitely give it a try. Best, Intersound
Are you using Altiverb? I've been getting these all the time since updating to the most recent version of Altiverb.
Will Russell Electric Wilburland Studio https://linktr.ee/wilburland M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS |
Hey Will. I was suspect of the same thing! Seems to only happen with sessions that have Altiverb instances.
Strangely, the right click trick worked for me also.
Newest Pro Tools on mac & pc. |
Error Message When Opening Sessions | Gorbies | Pro Tools 11 | 1 | 04-23-2014 10:11 PM |
DAE Error -9124 while opening OsX Sessions | sonnie | Windows | 4 | 04-02-2013 06:49 AM |
Opening 6.x sessions in 7.3.1 error | mr.armadillo | Post - Surround - Video | 0 | 01-29-2007 12:26 AM |
Plug-in can't be activated - DAE error #-9105?? | dingobiatch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-04-2007 02:08 PM |
DAE error #9105 | tritonkorg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-07-2005 08:48 AM |
