protools vs. reason midi problems
hiya, i'm hoping to find someone who has a solution to a somewhat strange midi problem.
when i have both reason and protools running at the same time, whenever reason is in the foreground with protools in the background, reason stops responding to midi events. if i switch back to pt in the foreground, reason responds to midi. i have plenty of apps i run at the same time (pt, reason, refuse, absynth, reaktor) and reason works fine in the fore or background as long as pt isn't running. i tested absynth and reaktor to see if they had the same problem, and they don't...only reason in the foreground creates this anomoly. system: g4 733 reason2 ptle5.0/digi001 oms2.3.8 midiman keystation 49 macos9.2.2 thanks in advance for any light that can be shed on this problem! -scientific |
Re: protools vs. reason midi problems
GO to OMS set up. Check the box that says " Run midi in backround".
THats it. |
so simple, yet so hard to find...
thanks, you've saved the day! -scientific |
Hey guys, I can only use one MIDI Channel in PT running Reason Sound bank. When I try to use another channel, my computer froze. Do you have any ideas??
Thanks! 733MHZ, 9.1, 640RAM |
Problems w/ Protools/Reason | daChayce | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-07-2010 03:56 PM |
Audio problems w/ Reason and Protools 7.4 | Tom Brandt | Tips & Tricks | 9 | 07-23-2008 06:54 PM |
Getting Reason midi into protools!!!!!!!!!!!!!! | outtareach | MIDI | 2 | 04-27-2007 02:36 PM |
Reason, Midi, and protools | shakobe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-12-2003 08:49 PM |
Reason, RME, PTle and midi timing problems | bennals | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 01-22-2002 03:58 AM |
