Old 05-28-2019, 09:15 PM
Default Re: Ctrl Key Doesn't Work
Originally Posted by chrismeraz View Post
Can anyone help me out? I'm still struggling with this. Not having basic copy and paste shortcuts is killing me, never mind switching between mix and edit views!
Unfortunately I suspect we've pretty much run out of ideas.
What did the Windows 10 keyboard viewer show you? Did it recognized all the keys being pressed, and had the same behavior when you used the on-screen keyboard using the mouse to click on the screen buttons?
I've had a high-end mechanical keyboard that had a hairline crack in the PCB. Depending on how you used it, pressed some keys etc. some other keys nearby (or well in a line across the keyboard following the crack direction) to the one pressed would not work. And that's why I wanted you to check all the keypresses are registering with the keyboard viewer while trying the key combinations.
And/or just try another keyboard.
Check you don't have any third party keyboard mapping utilities installed. maybe something was installed with some other software or somebody else (client in the studio?) might have installed something.
If none of that helps then I'd find/make a spare disk partition and do a full clean install of Windows, Pro Tools and ILM and test.
Old 05-31-2019, 12:02 PM
chrismeraz chrismeraz is offline
Thanks Darryl. Yes, keyboard works fine. I contacted Avid but they also don't know - looks like I'll be reinstalling the OS this week.
I have to reinstall the OS several times per year for weird problems like this. It takes days to get everything back to normal. I'm under the impression it isn't like that with Mac - do you think it's true?
ATC SCM50ASL
Apollo x8
MacBook Pro M1 MAX
Pro Tools Studio
www.studioaix.fr
Old 05-31-2019, 12:58 PM
ChuckS ChuckS is offline
Did you try uninstalling the Keyboard device in Device Manager or remove it in Devices and Printers? Right click on the device, then uninstall or remove it. On system restart it will reinstall and reconfigure the keyboard. Maybe worth a shot.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 10-19-2019, 02:15 AM
paulmellors paulmellors is offline
I have the same issue with CTRL + A not working.
Keyboard is fine. VERY frustrating
[B]Pro Tools 2018.4, C|24, X32 Rack, Win 10, Waves 10, Komplete 11, composers collection
Old 10-23-2019, 05:22 AM
RiF RiF is offline
Whenever I switch from PT to another application and back, some shortcuts (all with ctrl key, like switch edit/mix, split clip etc.) don't work anymore.
Pressing Alt-+ (this is on my German keyboard, the actual shortcut is for "Window | MIDI Event List" which is Alt+= on US/En-Keyboards) twice fixes this :-O.
Weird...
Anyone else has this? Any fixes?
Last edited by RiF; 11-05-2019 at 10:24 PM. Reason: added shortcut for non-German keyboards
  #16
Old 10-23-2019, 05:13 PM
DontLetMeDrown DontLetMeDrown is offline
Ctrl + = and and shift + scroll wheel shortcuts occasionally stop working for me on PT Ultimate + Win 10. Then I go to the mix view and scroll the wheel, it works fine. Then I go back to edit view and everything works again. Annoying to say the least. Going to try Alt + + twice next time to see if that fixes it faster.
  #17
Old 11-05-2019, 10:25 PM
RiF RiF is offline
I just edited my previous post. On non-German keyboards, it's Alt+= (for "MIDI Event List"). Pressing it twice revives my dead shortcuts somehow.
[EDIT: the following is wrong]
My guess is that the fix lies in the fact that a Pro Tools-owned client window (MIDI Event List in this case) opens and closes after PT lost focus of it's main window into another application.
[/EDIT]
  #18
Old 11-06-2019, 12:15 AM
TrentWilliams TrentWilliams is offline
Have you tried turning keyboard focus on/off .. ?
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
  #19
Old 11-07-2019, 08:12 AM
RiF RiF is offline
Yes. Does not help.
  #20
Old 02-18-2021, 10:53 AM
Vincent Jacobs Vincent Jacobs is offline
Weird...
Exactly this. I switched from Mac to PC a few months ago and returned a keyboard, thinking it was faulty. The bug remains.
For some reason Pro Tools doesn't recognize ctrl input which is frustrating like nothing else. After using an alt shortcut, like when switching to slip or grid mode, they work again. Until you switch windows or apps again...
Anyone figure out a proper fix yet? Is there some Windows software running in the background claiming the ctrl key or something?
192 I/O doesn't work with PT 11 HD djkikis Pro Tools HDX & HD Native Systems (Mac) 31 02-24-2014 03:08 PM
8.0.4 doesn't work GuitarMessiah777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 36 07-11-2010 10:10 PM
Two New C24's Mic Pre #16 Doesn't Work!!! MARVINBASS ICON & C|24 11 05-08-2010 10:40 AM
New Toy doesn't work G. Klopfenstein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-25-2006 01:49 PM
My two day 002 doesn´t work already!!! Punkest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-29-2003 10:07 AM
