Old 05-28-2017, 05:13 PM
djbassvixen djbassvixen is offline
Default Is there a way to delete tags that show up in the Assign Tags Pop-up Window?
I am going through my whole library of sounds and samples and adding tags to everything. It may seem trivial, but for a large number of samples, the time adds up. After I type the first letter, it automatically suggests tags from the list of default existing tags based on alphabetical order (and not most frequently used). For example, if I type "H" the first thing it will autofill is "Hammond." If I could delete some of these tags that I will never use, I could save a lot of time by having it autofill to tags I actually use. I could type one or two letters, press enter, and then move on, as opposed to having to type out the whole word. I have read the manual and it does not address this. Any suggestions?
Secondly, if I accidentally create a new tag in all lower case, without capitalizing the first letter, it seems it will forever appear in all lower case. I think if there was a solution to the above problem, it would probably fix this as well.
Side note: Yes, I am OCD.
macOS Sierra Version 10.12.5
Pro Tools 12.7.1
Old 02-23-2018, 07:47 AM
Elphara Elphara is offline
Default Re: Is there a way to delete tags that show up in the Assign Tags Pop-up Window?
Hello djbassvixen
i'm having a similar problem except I'm trying to create tags and maybe delete them if need it
I posted this a few months ago :
"Hi,
Can you help me, I wish to know how to create a new custom Tag in workspace?
I don't see any button " create a new Tag " in Tag Pop Up menu.
THX, Elphara."
I received no reply.
Since you seems to work on a 'tag" problem, maybe you can help me
Thx
Elphara
Old 12-31-2020, 12:47 AM
gills gills is offline
I'm looking for a solution for this as well. Does anyone know where the default tags for Soundbase workspaces live on the computer?
CD ID Tags? madlove 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-16-2006 10:47 AM
CD and song tags? richsorr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-08-2005 10:39 AM
ID tags when burning? silverlode 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-02-2004 12:08 AM
Can PT 6.0 put CD ID tags in the audio? johnnyv Pro Tools TDM Systems (Mac) 4 07-04-2003 02:21 AM
Tags on Mixes RDOG 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-22-2002 02:41 PM
