Old 03-09-2014, 12:13 PM
Cartoonguy Cartoonguy is offline
Default Pitch II does not work properly!
I have used the Pitch Shift plug in that comes with Pro Tools for years to pitch voices up maybe one semitone. It always sounded great, but now I have Pro Tools 11 and when I use Pitch Shift II to pitch, say, one semitone, it comes out with very noticeable distortions and kind of bubbly sounds here and there, like it's underwater. Not really useable for anything serious.
This surprised me because I had been using this feature on older versions for broadcast work. Never a problem. So I got an old copy of Pro Tools 8 and tried pitching the same sample up one semitone. Lo and behold, it sounded perfect. Same thing in PT 11 and it sounds terrible. Totally unusable due to the noticeable distortions, or whatever it can be called.
Why is Pitch Shift II in PT11 proving to do such a terrible job compared to the old Pitch Shift in PT8? I am using a brand new iMac, by the way.
Old 03-09-2014, 02:16 PM
Sparky1 Sparky1 is offline
Default Re: Pitch Shift II does not work properly!
Is there a way for you to reload the plug-in? Maybe it's just not happy...
Sparky
Old 03-09-2014, 04:41 PM
The plug in just came with Pro Tools, so I don't know how to do that, but I will call Avid on Monday to ask.
Old 03-10-2014, 08:29 PM
bradch00 bradch00 is offline
I tried the plug-in with a slight distorted guitar and it didn't seem to impart anything that wasn't already there…. I moved it up a 5th and 7th.
What settings are you using and I'll try those?
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 03-10-2014, 08:36 PM
I'm doing this with voices, not singing, but actors doing voice for animation, so very different than a distorted guitar. You could try pitching some voice up 1 semitone and see how it sounds for you.
Old 03-10-2014, 09:59 PM
mrtomcat mrtomcat is offline
Other than it needing a tremendous amount of resources it's working really well on my end.
I am not experiencing any distortion
Old 03-11-2014, 07:00 PM
Good news, sort of. I got to speak to a very helpful Avid Support guy and he tested the issue right then on his own machine and found the same issue as me. That is, the output quality is noticeably inferior. He suggested I used Pro Tools 10 as it is included with 11 and comes with the original Pitch Shift plug in. So I installed PT10, tested and it works great, just as before.
That's really good, but I am still amazed that Avid releases an updated Pitch Shift plugin which is so noticeably inferior in the output quality that it is useless, at least the way I need to use it.
Old 03-19-2014, 01:20 PM
tanjerinepost2 tanjerinepost2 is offline
I have the same problem and on an animation project, also you used to be able change duration with the old version of Pitch . I know that Time Shift will do that but the pitch shift in Time shift isn't nearly as good as the old Pitch. The quality on Pitch II even dropping a semitones is just rubbish... Can we have the old one back please avid .
Mac Pro TrashCan 3.7 Ghz Quad Core
AJA Video Op
PT 11.3.1 2xHDX
S6 32 Fader
32 Gb Ram
Old 03-19-2014, 01:30 PM
I have heard that Avid recognises that this is an issue with Pitch 2 and are looking into it. Shocking to me that this was not noticed before it was released. I don't get that at all, but hopefully they will fix it. For now, using Pro Tools 10 just for pitching does the job.
Old 09-11-2014, 09:10 PM
brummy17 brummy17 is offline
has anyone heard whether Avid are close to resolving this problem? The results of Pitch 2, and even Waves pitch plugs, are terrible in PT 11!
I can't get my Mic to work properly Djgman925 macOS 8 08-22-2013 01:53 PM
does protools ever work properly? pinnacle macOS 9 10-24-2011 04:37 PM
AudioSuite does not work properly. ali3 Pro Tools M-Powered (Mac) 2 04-15-2009 05:13 PM
882 will not work properly with 888 dwall Pro Tools TDM Systems (Win) 0 08-30-2007 12:20 PM
Command 8 not work properly webby ProControl, Control|24, Command|8 3 07-21-2005 09:41 AM
