Old 06-02-2019, 10:03 PM
Led Led is offline
Default Waves Ren Comp switching off lock on centre dynamics section
So this is a bit odd, but if I lock the centre section dynamics and eq, then select an insert on any channel it all behaves as expected, except if I select Waves Renaissence Comp that is on any insert, on any channel, then the lock on the dynamics section in the centre switches off and R comp appears in the centre dynamics section.
But - if i select any insert with any plug other than R comp, then use the bank/cycle button to get R comp to come up on the channels section, it doesn't unlock the centre dynamics section and jump into it. Doesn't happen with the Custom Fader plugin set either, just pressing the Sel on the insert.
This doesn't happen with any other dynamics plugs, just R comp, and it happens regardless of Rcomp being set as my default dynamics in the PT prefs or not.
This is on PT 12.7 can anybody replicate it or had it happen on other versions? Is R Comp the HAL of dynamic plugins? Please send help..
THanks
D-command EQ-Comp section focus [solved] Boe Larsen Pro Tools HDX & HD Native Systems (Mac) 2 07-12-2017 11:25 PM
Waves eMo D5 Dynamics Wall2Wall AAX Plug-ins 12 09-22-2015 06:48 AM
How well is 'Waves Licence centre' working? Ru_C AAX Plug-ins 22 12-16-2013 09:46 AM
Waves License Centre = Kafkaesque Nightmare = FIXED Carl Kolchak Windows 23 03-22-2013 08:44 AM
