Old 05-11-2019, 12:03 PM
Johnny Hulst's Avatar
Johnny Hulst Johnny Hulst is offline
Default Mojave breaks DADman software
DADman software gui is totaly unresponsive under mojave, it was fine under high sierra.
The MOM works just fine so volumes and sources selecting works fine... but the gui is not showing real live feed. Speakervolume fader is not even moving, selecting things with the mouse is not working.
Uninstalled DADman software and installed it again... no go.
First did a clean install with mojava... after that I tried an upgrade from high sierra were everything works fine... it breaks the dadman software anytime.
So for now I stick to High Sierra... but if someone knows the problem, let me know.
PT Ultimate 2024.03.0, Avid S1, Eucon 2023.11
16" MacBookPro (2023) M2 Max 12-core, 64gb Ram, 1Tb SSD, OSX 14.4.1
MTRX v.2.4.2.2 + dante card + madi baseunit + optical SFP 1300nm
MTRX-II v.1.0.5.2 + TB3 + 1x AD mic 8ch + 1x DA 8ch
MOM v.1.0.1.4 by DAD
Genelec 1237A Sam, Avantone active mixcubes
LA2a (1968), 1073 pre/eq, Neve RNHP, Wacom Intuos Pro
Furman P1400 AR E Power conditioner
Live-rack:
1x HD Native TB, 4x 192 I/O (64ch AD)
8x Yamaha HA-8 micpre, Rosendahl mif4,
Genelec 1031A, Presonus Monitor Station
Old 05-11-2019, 12:15 PM
BScout BScout is offline
Default Re: Mojave breaks DADman software
There's a warning on DAD's site that DADman does not run on Mojave.
Maybe Avid should integrate that into its notes in big, bold letters.
There's nothing to fix from a user-standpoint and DAD knows.
Old 05-11-2019, 07:53 PM
Glad I saw this, was thinking of upgrading today.
https://lukehoward.com/
Old 05-12-2019, 04:30 AM
Thanks, I didn’t know this... I downloaded the DAD software from the Avid site, were ofcourse is no sign of this. From now on I will check the DAD site too.
Live-rack:
Old 05-12-2019, 03:34 PM
paulo m's Avatar
paulo m paulo m is offline
There is, but in small letters Taken from AVID site:
Pro Tools
macOS Mojave (10.14) is supported with Pro Tools 2019.5 and higher.
Note that the DADman software for Pro Tools | MTRX is not supported with macOS Mojave at this time.
We´re also stuck with this as we had to buy a new MAC which came installed with Mojave. We have the new monitoring page on PT Control app but DADMan is not compatible and most stuff doesn´t work as you´ve mentioned.
I don´t understand why AVID announces PT compatibility with Mojave as let people that bought it´s most expensive interface MTRX out in the dark. Just because they are not the manufacturers of the MTRX and it´s associated software, it´s not an excuse for their responsability. No wonder why people are switching to Windows...
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
Old 05-13-2019, 07:05 AM
DAPG DAPG is offline
Thanks for pointing out that Dadman is not Mojave compatible. I am in the process of upgrading our facility to PT2019.5 and Mojave but without Dadman support, it is a real problem for some of our rooms.
Avid, is there an ETA on Dadman support for Mojave?
Roy Machado
Dallas Audio Post
Old 05-13-2019, 01:53 PM
jgaz jgaz is offline
I'm having mixed results with DADman and Mojave, a combination of rebooting my S6 and reloading profiles can get DADman talking with the S6 and MTRX. Not ideal, but this is why I upgraded on a cloned hard drive and not my internal hard drive.
-Jeff
Old 05-13-2019, 03:41 PM
-Jeff
Is this what you're describing:
Monitoring page inactive unless Monitoring application Is focused
The S6 Monitoring page does not show sources unless the monitoring application (such as XMON EUCON) is focused on the workstation, even if the S6 Monitoring section is locked to the monitoring application.
That is in the "What's New in S6 19.5" Known Issues section. It's highly annoying (especially if you can't guarantee the system/desk won't be rebooted.) I had to deal with it multiple times yesterday and it was driving me nuts because it sometimes just doesn't grab and there doesn't seem to be any consistency (this is with a Sierra system connected to the S6 and latest DADman.)
But that isn't the DADman problem with Mojave which appears to be UI related (so Eucon control still works behind the scenes.) Your problem is something else Avid needs to fix.
Old 05-13-2019, 05:01 PM
paulo m's Avatar
Experiencing the same thing on PT Dock. Unless I click/focus on DADMan window, PT Control shows nothing on the monitoring page. If I unlock only the monitoring on Eucon, everytime I click on PT window, things go away again.
Regards,
Paulo M
Old 05-13-2019, 06:43 PM
That's not the same thing (I have the Dock too and I know what you are talking about.) With the Dock/Control app, when you start your computer (and DADman), you click over to DADman with Monitoring unlocked on the Assign page, then lock it. The monitoring will then stay and you can go on to Pro Tools and the Monitoring will stay locked. Though it says it is "assigned" and locked through reboots, Eucontrol isn't refreshing the graphics for monitoring through reboots (if you notice, the monitor knob on the Dock stays working though.) So after a reboot/restart, you have to unlock what Eucontrol says is locked, put DADman into focus, and relock the monitoring section.
This is the workaround for this.
The S6 thing is a lot worse. It's like it refuses to grab DADman's info (though some of the things are working even if the GUI is not updated.) And no repeatable order of events seems to get it to work again (tried a bunch of different ways.) At some point, something just triggers it to work again and it will finally work again with the S6 completely.
And once it does, it stays locked (until a reboot).
I was trying to write up instructions for what to do for others who use our S6 but had to give up because there's no direct instruction to give other than keep trying to close and restart DADman while the monitoring screen is visible until it works. And having Pro Tools off until it does seems to help.
MTRX Reference (Ref) Button in DADman Software jb_trm Pro Tools | MTRX & MTRX Studio 5 05-25-2022 02:08 PM
Mojave? hanksinclair Artist Series 3 05-03-2019 03:19 PM
DADman/PROmon on MTRX with OSX above 10.12 Sierra paulo m Pro Tools | MTRX & MTRX Studio 4 03-01-2019 04:05 PM
Mojave ? Riquier macOS 89 02-26-2019 06:41 PM
Sum and Intercancel between MTRX DADman and S6 laki Avid S4/S6 1 12-27-2017 04:18 PM
