Old 03-01-2011, 08:35 AM
DTSR DTSR is offline
Default MC MIX PC: Bonjour/Input Director conflict
Recently installed PC driver for Euphonix MC mix, Windows 7 Pro 64, and faced issues with mouse/keyboard input on slave PC.
After trying a number of things, I deactivated the Apple Bonjour service that Euphonix are using with the MC Mix driver and everything was as it should be.
This means I can't control my slave machine properly while using MC Mix on the master, which is a bit of a hitch, considering everything worked fine when I was using the MAC/PC network work-around.
Any other Input Director users out there experience this problem?
Is there a solution?
Using Bonjour Browser to troubleshoot EUCON 3 DanielEUCON Artist Series 7 01-22-2019 02:06 PM
EuCon vs Bonjour on Windows 8.1 bonestonne Artist Series 6 10-31-2013 02:39 PM
Bonjour! Emcha_audio Le Forum en Français 0 04-21-2013 04:03 PM
ADR when actor and director in two different locations rabinrocks Post - Surround - Video 16 04-23-2012 04:35 PM
Creating Cue points for Director 7.0 lrosier Tips & Tricks 1 06-25-2000 12:13 AM
