#61
Re: Start key problems
No update necessarily - we're keeping an eye on this, but if it's a hardware issue with particular keyboards there may not be a whole lot that we can do about it. We would have to investigate why particular keyboards have the issue and see if there's any way to work around it.
#62
Happens sometimes for me also. This on my LE setup, though, with the keyboard shipped with the Dell 5150C.
Regards, John
****************** John Rammelt Producer / Composer / Post Hajp AB old site: Soundfactory JPR |
#63
Re: unofficial \"Problems with PT7\" thread
#64
Re: Disk allocation option
Also - a quick way around the 'HUGE mess' that won't take a long time is to do a 'Save Session Copy In' and choose the option to copy all audio files. This will consolidate all the audio files for the session into a new Audio Files folder that will be in the new location that you save the session copy in. |
#65
I'll remember to use "Save session copy" option next time. Thanks! |
#66
Anyone having ISSUES WITH METER CHANGES used in conjunction with Identify beat ??
The linked thread was created on an HD III Accel XP - PTHD 7 In the linked file, in that post... I can not "Get rid" of both Meter changes, following the initial Meter change, (Which should be the 1 and only for the session) I can only set the start time for all 3 markers, at the same time, which is really a "Workaround" not a fix.
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
#67
We have 4 HD2 & 1 HD4 Systems and all show the same very annoying "Start Menu" behavior as mentioned above and in greater detail the LE on XP forum:
7.1cs4 / XW8000 / Magma 7 slot / XP sp2 / V10 / PT custom keyboard all recently freshly re-installed by our Digi Dealer (SMM in Germany) I waited for cs4 in the hope that such improvements had been dealt with - please change it back to how it used to be! If you need more details just let me know Thanks |
#68
We think we have reproduced the "Start" key problem. Amazingly enough, it only happens on one system we know of at Digidesign, but it's the same thing you're seeing, we believe.
It may take a bit to get this fixed, because since the Start key touches so many areas, we need to make sure the fix doesn't break something else. We realize this is quite understandably trying your patience, but rest assured, we're working on it. Danny Caccavo Product Manager Digidesign |
#69
Re: Dual-monitor setup maximizing trick
I [bleep] hate you Digi, for [bleep] this up. |
The Official Unofficial Windows 7 Thread | Benoni | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 776 | 08-24-2014 04:41 PM |
THE UNOFFICIAL "DAVE C" TEST RESULT THREAD | scuzzytim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 79 | 07-14-2010 08:21 PM |
The unofficial PTLE bottom-feeder thread! | M.Brane | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 07-18-2006 06:07 PM |
---unofficial BTD report only thread--- | nikki-k | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 59 | 12-02-2003 04:29 PM |
