Old 10-17-2020, 01:38 PM
Porky Porky is offline
Default Odd TC issue
So I received a QT screener from a client. Importing it into PT shows the tc rate on the video track as 23.976 (in white-no error). But the TC does not stay synchronous. So I scrolled until I found the issue, which is that the screener (burn-in) jumps from 58:59;23 to 59:00;02. And yes, it does have the semi-colon which generally denotes drop-frame. I'm sure this is simple, but not sure what I'm missing here. My assumption is that they made the screener incorrectly, but just not sure how.
thx all
Dave
CBS TV Distribution/On-Air
PT 2019.6.0
S3
Old 10-17-2020, 02:47 PM
tomaspal tomaspal is offline
Default Re: Odd TC issue
If you open up the video in Quicktime and go through frame by frame, do you see the same issue? If so, it definitely sounds like there was an encoding issue before the video file got to you.
Old 10-17-2020, 03:13 PM
Yes, the TC burn-in shows the jump. I'm just not sure how you would create a DF 23.976? I'm sure it was an encoding error, just not sure how. I want to be able to convey the issue to the client and give them an option to resolve, but until I can have an idea of how they "screwed it up" I don't want to make that claim.
Dave
PT 2019.6.0
S3
Old 10-18-2020, 02:18 PM
bewk's Avatar
bewk bewk is offline
Sounds like the burn-in is on a timeline that is drop-frame while the export was done at 23.976. If the overlay is set to match the TC of the sequence it will display DF. They just need to pic a spec. Are they mastering in 29.97 DF or 23.976?
-Chris
• PT HD|Native 2020.9 on 10.13.6 (Angelbird SSD) // MacPro (4,1 to 5,1) 12 Core 3.46 GHz // 24GB // AJA Kona LHi // OWC FW800, USB 3.0, eSATA // MTRX Studio
• PT HD 11.3.2 on 10.13.6 // MacBook Pro 17" 2.66 GHz i7 8GB RAM
• Avid Dock,
Artist Series Mix & iPad 7th gen & Eucon 20.5
• DADman/Eucon monitoring
• BSS (DAN + 100), QSC DCA 1644, JBL 7 Series
www.quesound.com
HTML code is On
Paste automation over multiple tracks issue, Fade Move Issue WinstonDeath Pro Tools 2020 1 04-09-2020 02:31 PM
PT 9.0.6 Start/Stop Issue and Plug-in Instrument Issue ZDF macOS 0 01-14-2013 02:47 PM
Some regions had invalid bounds... non-issue becoming a crash issue!!! krichu Pro Tools 9 3 12-11-2010 04:49 AM
Digi 002 Power Harness Issue or Firewire Chip Issue? Nish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 35 05-07-2010 01:25 PM
002 Console Issue, Faders Wont Move (grounding issue?) guitar486 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-01-2010 03:58 PM
