#21
Re: Mac G4 1.25 Single Processor, AM3 card, can't find the card...
Yes, miles is right. You need to have the special version of OS9 that came on the restore disk(OS9 general). I think what's happening is the version you are booting from your SCSI disk isn't able to access all of your hardware properly(namely your pci slots).
I'm amazed you can even get it to boot, I could never even get an mdd to boot from any of my OS9 retail disks. |
#22
Delta Music Belgium: will ANY of the grey OS X/9.2 DVD installer discs work? Or will it have to be specifically for the 1.25 MDD G4?
#23
Here is a good reference of what these machines are and when then were made: http://www.everymac.com/systems/appl...wermac-g4.html Note that the FW800 models were not bootable in OS9, so their restore disks did not include the Os9 general. FW800 models included a single 1.0GHz, a dual 1.25GHz, and a dual 1.42GHz. Confused yet? |
#24
I don't know the details, but I acknowledge the reference to the FW800 vs. FW400 machines.
MilesOfWire: [email protected] is my e-mail. ANY help in finding the appropriate install/restore DVD will be SO appreciated. I nearly gave up on this project and was shopping for a 466MHz G3 (fastest G3?) as I can get SD and the AMIII card running on the G3 machines without a problem. And as it is Christmas eve, I'll dispense with the political correctness and wish everyone a Merry Christmas. Chip |
#25
So yes, any of the grey OS X + 9.2.2 DVD installer discs for G4 will work. But beware, there are also grey installer disks for iMac's and PowerBooks, these will not work on a G4! (but 'iMac' or 'Powerbook' is written in large on the disk, even larger then 'PowerMac G4' is written on the disk you need)
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
#26
#27
OK gang... I'm at the end of my rope.
I've spent the past few weeks trying to find a copy of the original install disc for my 1.25 MDD G4. This seemed to be the consensus as to why I can't get the Mac to see the AMII card. I just finished installing the OS X and 9.2.2 combination, and booted into OS 9. Installed SD 2.8.3, then DSI 5.0, rebooted again, and was staring at the same frustrating Hardware Setup page that's been driving me nuts for months now. I see: ------------------------- Select Card Type: AudioMedia ST II, Bridge I/O 442 Card Project, Disk I/O Cards to use: Card 1: (with a pulldown box around the word) None ------------------------- I think what the machine is trying to tell me is that is just doesn't see the card. And I am stumped. Anyone have any ideas? Chip |
#28
In Hardware Setup I can see exactly the same as you do, but for 'Card 1' I can choose 'Slot 3' (my AMIII is in slot 3).
Some questions: - did you install DSI 5.0 and DAE 5.0? (not only the DSI) - what happens if you put the card in a different PCI slot? - I asked you this before, can you see the card with Apple System Profiler'? It should show something like this: pci11af,ee40: Type: Audio Bus: PCI Slot: SLOT-3 Vendor ID: 0x11af Device ID: 0xee40 Revision ID: 0x0011 If Apple System Profiler can't see the card, maybe your PCI slot(s) are broken or full of dust and need cleaning I would start with checking with Apple System Profiler and try every PCI slot available if needed... If Apple System Profiler can see the card, the problem is not hardware but software (DAE/DSI combo and/or corrupt Preferences). Can you confirm Apple System Profiler can see the card?
#29
In the system info, I have to assume this is the info for the AM3 card cause it doesn't actually identify it in a manner that says "hey... this is your AM3 card".
PCI Slot 3 >PCI Slot Card type: not available Card name: pci11af,ee40 Card model: -1 Card ROM number: not available Card revision: 17 Card vendor ID: 11AF I've tried a different slots at random, I'll have to try them all systematically (but not tonight). The other thing to mention, I put the card in a 733MHz G4, and had the same (lack of) results. (this to possilbly rule out a bad/dirty slot). |
#30
DAE and DSI are both version 5.0.
Just want to buy a single HDX card ? | Firechild | Pro Tools HDX & HD Native Systems (Mac) | 4 | 11-28-2011 10:52 AM |
Single slot monitor card? | efisch | Post - Surround - Video | 7 | 09-25-2011 10:41 AM |
ATTO Single SCSI Card and a G4 - Possible?? | worldsend | Pro Tools TDM Systems (Mac) | 2 | 11-16-2005 11:22 PM |
G4 533 Single Mix Plus PT 5.01 Doesn't see Mix farm card | Count Zero | Pro Tools TDM Systems (Mac) | 6 | 02-17-2001 09:47 AM |
Can I use an 888 and 1622 on a single Mix Card ? | Evolution | Pro Tools TDM Systems (Mac) | 1 | 02-27-2000 07:13 PM |
