Old 10-12-1999, 07:33 PM
tomcat tomcat is offline
Default late night session in progress please help
i need to combine 5 reels of edited music for a film that are at 48k with 5 reels of efx, bg, dialog, and adr for the same film, that are at 44.1. i do not own session browser. is there any way??? i hope, i hope, i hope.
i tried converting all the music audio to 44.1 using gearbox, then opening a copy of the session and pointing to the 44.1k audio (i temporarily changed the names on the 48k files using filebuddy) then i set the session to 44.1 in the set-up window. everything was messed up. the wrong part of an audio file was in the region, and all was out of sync. why? please help, brothers and sisters
thanks
[This message has been edited by tomcat (edited 10-12-99).]
tom
www.tompaul.com
Old 10-12-1999, 07:57 PM
drBill drBill is offline
Default Re: late night session in progress please help
tomcat,
I'm not sure that I completely understand your perdicament, but I think that I'd
1.) bounce to disk the music files. (perhaps from 2 pop to 2 pop - see below)
2.) Then covert/import them into your 44.1k dialog/sfx session. This could take a Looooooonnnnng time depending on how much music you have. Don't use tweekhead unless you don't want to work until tomorrow nite!!
3.) re-spot them. After a sample rate conversion I don't know if they will auto-spot correctly or not. (never tried that)
What you could do is when you bounce to disk, you could bounce from the 2 pop at the top of the reel to the 2 pop at the end of the reel. This will leave you with one long contiguous region that will be simple to re-spot in your 44.1k session. The downside is that it will take a while to bounce and quite a while to convert/import. Hope you've got a lot of coffee.
Good Luck!
drBill
Old 10-12-1999, 08:08 PM
i appreciate the response, dr., but this won't work for two reasons: i need to continue editing, so a contiguous region won't allow for any "opening up" of the regions, and the other reason is that this is a two hour movie with lots of music and i have to deliver the entire mix in two days. i will barely make it hacking through as it is, let alone waiting for 10 hours of file conversion. if i had session browser, life would be good again. do they make a demo of that or does anyone have a copy i could borrow for a day???
tom
www.tompaul.com
Old 10-12-1999, 11:11 PM
If you're in a hurry and will settle, then you could transfer the 48kHz music audio to MMR-8, DA88 or ADAT analog and record at 44.1kHz, then retransfer the 44.1kHz recorded music to your dialog, fx, etc. session digitally.
You will have to decide if the D to A conversion to change the sample rate is any worse than using the sample rate conversion algorithm that you would otherwise use. Do you have an AD8000?
Good luck.
Rail
Recording Engineer
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 10-13-1999, 12:34 AM
thanks for the idea but we need to continue editing the music, so if we recorded it out and brought it back in, we couldn't access audio outside of the current region.
tom
www.tompaul.com
Old 10-13-1999, 09:04 AM
Since you need to keep editing and have to deliver so quickly, I suggest that you run two seperate sessions up until you need to deliver. Then rent an extra Pro Tools for your dub and run both systems in tandem.
Old 10-13-1999, 10:51 AM
yeah, i'll just lay the tracks out to da-88 when i'm done editing and have that chase and come in on auxes in tdm. there's always a way. thanks folks.
tom
www.tompaul.com
Old 10-13-1999, 09:19 PM
hrob hrob is offline
If you convert the sound effects to 48K, you could use lower quality (i.e., faster SR conversion). Just a thought.
Late Night Recording Session Come To an Abrupt HALT! Monaco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-15-2009 10:52 AM
MIDI Help needed in SETUP - late night messin... IntelDoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-07-2003 09:54 AM
Here's our late night link... Stone Knife 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-22-2002 05:29 AM
late night, screen's too bright clarpark Pro Tools TDM Systems (Mac) 3 06-28-2000 10:32 AM
late night session in progress, please help tomcat Tips & Tricks 0 10-12-1999 08:28 PM
