  #21
Old 09-17-2019, 11:29 AM
WorldStudios WorldStudios is offline
Default Re: Not you again, Mr. -9173
Kiitos. Now I am out of rope. :)
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
  #22
Old 09-17-2019, 11:37 AM
JFreak's Avatar
JFreak JFreak is offline
You're welcome.
Now is there anything else I can help you except the finnish language thing?
Janne
  #23
Old 09-17-2019, 07:20 PM
capt kirk capt kirk is offline
Sounds to me like there are temp buffer issues , other wise it would happen all the time......probably the source of all these issues all along and they just cant wrestle it to the ground.....otherwise it would NEVER appear again., so the OBVIOUSLY havnt fixed it entirely
www.kfaudio.ca
  #24
Old 09-20-2019, 02:11 PM
innesireinar innesireinar is offline
Since I removed kontank 5 from the plugin folder I stopped having AAE errors except when using Ozone that eats all the cpu resources of my old mac
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
  #25
Old 09-20-2019, 02:40 PM
clivvy clivvy is offline
news flash 9173 is still a problem even when you update it comes and goes sometime at the start of play back or when you least exspect it avid needs to seriously look in to this even protools users including my self with powerful computers with fast cpu native cards or AAX are dealing with this hopefully the next update will address it!
  #26
Old 09-20-2019, 02:46 PM
Paul_5 Paul_5 is offline
Originally Posted by innesireinar View Post
Since I removed kontank 5 from the plugin folder I stopped having AAE errors...
Me too. I keep it for using my Quantum Leap Orchestral sample library, and just use it in Cubase for that sort of thing, then freeze the tracks and import them into ProTools later on.
  #27
Old 09-20-2019, 03:25 PM
Does QLO work in kontakt 6? PT seems unaffected from this last kontakt version. I'm replacing k5 with k6 in all the sessions with kontakt. AAE errors are finally gone
  #28
Old 09-20-2019, 05:12 PM
they will be back!
  #29
Old 09-20-2019, 07:38 PM
ZEUSS ZEUSS is offline
Honestly i still think its more graphics oriented. After I see the error, I can literally watch my cpu not jump as much once I close the mix and edit window but keep the system usage window open. I also still see it stop when it gets to certain automation info in the edit window. I still see this on clean installs with up to date plugin installs and latest approved OS installs. I see it with internal fast drives (trashcan internal) and also fast SSD's. Doesn't matter. I see it with NO plugins active on a session. Did a transfer the other day from a tape based digital machine. Stopped 2 times! No plugins, 8 tracks!
Its time to get this straightened out. Its been YEARS now since version 10 where this wasn't an issue!
And that goes for 6101 errors etc.
Yeah yeah yeah, ditch permissions and do the same stuff over and over. BS
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
  #30
Old 09-22-2019, 04:17 PM
reflexson reflexson is offline
I had an issue like this and it turned out to be a ram stick that was failing. I would run a mem test
Paul Cox
www.226recordings.com
9173, 9173, 9173... Hellooooo Rectifried Pro Tools 12 2 04-19-2018 12:50 AM
Dae 9173 danyg Pro Tools 2018 6 04-17-2018 04:04 PM
12.6.1 / aae-9173 anyone? lesbrunn Pro Tools 12 9 12-09-2016 03:43 AM
PT 12 - When 9173 is not actually 9173? taft_mashburn Pro Tools 12 2 10-06-2015 09:28 PM
