Anyway to copy plug in automation of a selection from track to track?
If I have two aux inputs with the same plugins on them and I want to copy the automation on all those plug ins from one track to another... Is there any way to do this automatically? Without doing it parameter by parameter nor by draging the plug ins themselves to the other track (since that would copy all the track's automation and I just want to do it in one spot).
Thanks! |
Re: Anyway to copy plug in automation of a selection from track to track?
Copy special and paste special should do it
select the area of automation you want to copy and as normal hit command + C to copy and then to paste the automation hit control + command + V
well i'll be durned. I could have sworn i tried that. Thanks fellas!
Even easier, just copy the plugin over and the automation will go with it. 1 second per plug to copy. Unless the plugin has different settings of course. Chris
hold down the option key and drag the plug in wherever you want.
Copy Audio Track Automation to Midi track controller (Mod Wheel) | cybercampbell | macOS | 3 | 05-11-2013 10:18 AM |
option/drag won't allow to copy selection, instead the entire track highlights | ltoth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-29-2009 12:01 AM |
Copy automation from mono to stereo track? | bb_aus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-09-2006 08:01 PM |
copy automation from stereo to 5.1 track not work | john1192 | Pro Tools TDM Systems (Mac) | 1 | 08-29-2005 11:19 AM |
can you not copy automation data from a mono track to a stereo track? | Felix | Tips & Tricks | 5 | 04-09-2002 06:32 PM |
