Old 11-02-2014, 12:25 PM
Victorzk Victorzk is offline
Default Pro Tools Express cannot locate MBox2 hardware
I know this has been discussed elsewhere but the solutions discussed aren't getting me anywhere, and I'm rapidly losing hair and braincells, also completely new to all this. I have an MBox 2 which came with ProTools Express ver. 10.3.4. I got this earlier in the year, and installation seemed to work fine. I could get into ProTools no problem. Due to a change in circumstances I didn't get a chance to use it until now, except that now as Pro Tools starts it throws up the message 'cannot locate hardware...check connections etc' . The Mbox2 I'm using, has all the lights coming on, and the Mbox control panel is happy to load and shows hardware connected. I've downloaded the latest Mbox driver from Avid, I've tried different usb ports. I've tried without the ilok dongle and obviously it wont load at all that way. I'm using PC with i7 processor. Win 7.... any suggestions? - PANIC OVER SOLVED! had another go at the drivers and this time it made a difference
Old 11-03-2014, 04:52 AM
sw rec sw rec is offline
Default Re: Pro Tools Express cannot locate MBox2 hardware
Did you disable USB power management?
Old 11-03-2014, 07:30 AM
nst7 nst7 is offline
Are you sure it's an Mbox 2, or Mbox 3?
The Mbox 2 never shipped with PT Express, because PT Express was not even introduced until after the Mbox 2 was discontinued.
I'm assuming you mean the Mbox 3.
If it is in fact the Mbox 2, that explains why it isn't working, and will never work, because PT Express only works with a few select hardware interfaces (which does not include the Mbox 2).
Pro Tools Express can't locate hardware. apoltorak6 Pro Tools Express on Windows 14 07-09-2017 10:08 AM
Pro Tools Express unable to locate hardware Sven80 Pro Tools Express on Mac OS X 1 06-03-2014 12:59 PM
MBox Mini UNABLE TO LOCATE HARDWARE Pro Tools Express electropunkboy macOS 4 11-18-2013 09:06 PM
Pro Tools Express Unable To Locate Hardware Psychic Denim FireWire & USB Audio Interfaces (Win) 1 06-21-2013 07:00 AM
Pro Tools Express 10.3.3 unable to locate hardware cfmfam Getting Started 2 05-16-2013 05:09 PM
