Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 09-28-2018, 05:04 AM
naughty G naughty G is offline
Default no audio past channel 32 in a 64x64 Dante setup?
I have ProTools Ultimate 18.7.0.201 on a MacBook Pro with OSX 10.13.6.
I am recording a show from a Yamaha CL5 using the Dante Virtual Soundcard v4.0.3.2
Everything is set up correctly and I can record all 64 channels of audio using Ableton Live 9.
However, in ProTools, while I get audio fine through channels 1-32, I cannot get any audio through any channels from 33 onward. I have tried deleting all my IO and resetting to defaults - it sees all 64 channels fine, but no audio for 33-64.
Has anyone seen this? Is it a bug? Is there some weird setting for recording more than 32 tracks?
Thanks in advance,
Gaetan
Still running PTHD TDM 10.3 in my studio, it never goes wrong.
PT Ultimate 2018 on the laptop, with all the bells and whistles through CoreAudio.
Old 09-28-2018, 05:13 AM
its2loud its2loud is online now
Default Re: no audio past channel 32 in a 64x64 Dante setup?
3. Pro Tools | Ultimate software supports up to 64 channels of I/O with HD Native hardware through DigiLink, and up to 32 channels of I/O through Core Audio and ASIO
Old 09-29-2018, 04:26 PM
Thank you for the info.
ProTools not so ultimate then, when a much cheaper app such as Ableton Live supports the full Dante capability of 64x64..
I find this baffling, is it a case of throttling capabilities just to force HDX purchase?
Old 09-29-2018, 04:38 PM
Yeah. Doesn’t make much sense to me either. Although you can use other non Avid hardware with the digilink cable if you’re running a Native system.
Waves Tracks Live is also a great free option for multitrack recording with Dante.
Old 10-04-2018, 11:27 AM
xrekcor's Avatar
xrekcor xrekcor is offline
One does wonder how many lost sales are compiling over time in relation to this issue. About to spend AUS$500.00 to crossgrade to Cubase Pro mostly for this very same reason.... money Avid could have gotten.... I still plan to use PT but at the same time it’s kinda allowing a competitor a chance at your customer base..... and then the reality is I might like Cubase even better.... then the 12 month subscription thing comes along and PT falls to the wayside......
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 10-04-2018, 12:26 PM
YYR123's Avatar
YYR123 YYR123 is offline
Yeah they pretty much don’t care
Like since ever....they are really slow in moving away from their old policies
Really slow....
Daniel
Old 08-04-2020, 12:49 PM
rune288 rune288 is offline
So I have just upgraded to pro tools ulimate thinking I will now be able to run my outboard past 32 channels and I have discovered as you did I STILL cannot use it. What in the actual F#@k Avid?? Back to Reaper I go then. Lucky I only signed up for a month of ultimate. I am slowly but surely learning that NOTHING is straight forward when it comes to pro tools. Or should that be NO tools. I have literally just wasted £90. I already had a standard subscription which I couldn't upgrade, I had to start a new subscription only to find out I have the dsame problem. I am SOOO pissed off right now.
Avid can I get my money back as I have no neecd for this extra subscription anymore. This truly is ridiculous.
Old 08-04-2020, 01:06 PM
JFreak's Avatar
JFreak JFreak is online now
Didn't you read the specs before purchase? Only way to get past 32 i/o limit is using HDN or HDX with DigiLink interfaces.
Janne
Audio "Dante" devices for commercial DenBurger General Discussion 2 11-19-2016 07:16 AM
Burl Audio B2 Bomber ADC with Dante whittybeats Buy & Sell 3 09-04-2015 06:01 PM
Audio from past two days of recording missing... ideas? keevhren Pro Tools TDM Systems (Mac) 25 09-15-2010 04:48 AM
channel setup? nate9 ICON & C|24 1 02-24-2009 03:03 PM
Audio Past Black & Network Spots SPC Post - Surround - Video 18 06-14-2005 11:14 PM
