Your go to vocal compressor?
Hi All -
I finally caved and bought the Wave's SSL bundle. This is rocking hard for my drums and guitars. However, even when I'm mixing on a real 4000 in the non-virtual world, I don't use the SSL channel compressor on vocals. I typically go for an LA-2A. Can anyone share what their "go to" vocal compressor plugin is. I've been engineering for a long time and already know that it "depends on the song, vocalist, etc". But, I also know I have a goto mic, compressor, eq, etc... that I try first and usually keep. So, share with us what your go to is. I don't have an LA-2A type plug, so right now.... I'm without a "go to" compressor in the virtual world. Curious, -Tom
http://SpeakRecords.COM |
Re: Your go to vocal compressor?
The URS 1970 is very nice. McDSP CompressorBank, Waves Renn Compressor, Sony Dynamics are also good choices.
STeve
macmandigital.com |
I'll second the URS 1970! its the closest plugin to my Tube-tech CLIB and its my favourite on vocals and guitar. Chris
Well, if you love the LA2A, I hate to say this, but you should check out UA plugs (1176 and LA2A), but only if you have a free PCI slot and are willing to get the UAD card and use a VST wrapper. The 1176 and LA2A are my favorite vocal plug ins, and very close to the hardware, but they are discontinuing support of their TDM plugs.
www.clifnorrell.com |
How's the Bomb Factory LA-2A? -Tom
the UA Tdm is my go to voc comp.better than the bomb factory IMHO
Too bad they are not going to support it anymore But it's working with 7.2 Francois
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1 - D-command 24- Trinnov Dmon6 |
I didn't bother mentioning the UAD La2a & 1176 TDM (which I love) because they have been discontinued. Still the URS 1970 is just as good.
STeve
macmandigital.com |
what's the reall skinny / reason on why they would not continuing the plugs after we spent the dough ton them will they work in 7.2? asthis could be a real detering issue.
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
If you scroll upward a bit, you'll see that Francois says they work in 7.2.
As amazing as it is, the Waves Renaissance Vox is actually really good at compressing vocals. It's not perfect and definetely not a tweak-all-you-want-as-long-as-you-wish type plugin, but it works very nicely.
Other than that, I've liked Sony Oxford Dynamics and BombFactory LA-2
vocal compressor ??...recommend one... | martin coria | Pro Tools M-Powered (Win) | 6 | 08-10-2010 02:49 PM |
Best Vocal Compressor / Compression Settings... | Nathan W. | Post - Surround - Video | 8 | 01-22-2008 12:23 PM |
Looking for the best vocal software compressor | crb | Tips & Tricks | 1 | 05-09-2006 04:56 AM |
Vocal Compressor Settings | Mayo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 11-19-2004 12:50 AM |
Vocal Compressor (What to Use) | JLEpperson | General Discussion | 2 | 07-09-2004 05:12 PM |
