Old 10-28-2019, 03:29 PM
RSLAMBERT RSLAMBERT is offline
Default Re: S6 Layouts
Hi Jeff, all we did is update this Mac and S6 to 19.9.Port 2 on the back of the master module is connected to the switch. Port "ethernet 1" on the Mac is also connected to the switch. Port "ethernet 2" on the Mac is connected to the house network. The service order is set so that "ethernet 2" (house network) is first, followed by "ethernet 1" (connection to the S6).
We tries swapping ports and addresses, no difference. Should we try reinstalling the MTM software?
Thanks again.
Old 10-28-2019, 03:46 PM
creativecontrol's Avatar
Thanks. So you tried using Port 1 on the S6 Master Module? If not, I would highly recommend giving it a go whether using an external router or setting the MTM to enable DHCP server on Port 1. It shouldn’t be absolutely necessary to set your surface NIC to be first in the priority list on the workstation however it would be a useful data point. Network configuration can be accessed from Settings>Surface>Local Options (gear).
Please let me know what you find.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
S6 v2.2 and Layouts Bydy Avid S4/S6 4 10-23-2017 02:15 AM
Layouts Peter Baird Avid S1, S3, Dock and Control App 4 07-05-2016 02:04 AM
Layouts are disappearing amolin Avid S4/S6 2 05-14-2016 07:34 AM
Layouts beyond modules brdst Avid S4/S6 4 09-23-2015 11:27 PM
Layouts Reckless Erik Artist Series 6 09-17-2013 07:21 AM
