Melodyne ARA Compatibility
When Protools will be compatible with Melodyne Ara technology ?
It would be a great improve for PT users. Thanks ! |
Re: Melodyne ARA Compatibility
+100
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
+100
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
+10000
Sent from my iPhone using Tapatalk |
Do any of you own the plugin? Works perfectly for me.
What does ARA integration do that the plugin doesn't? Carl
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
Scroll down, there is more information...
Aha Thanks Clausiii. Read on ipad and didnt scroll down. See it now
Thanks Again
NOTE: for anyone that has the Standalone version of Melodyne Studio ..
i tested something different but this came out of it .. if you even do one single Tweak the timing will be off the rest of the way down the track .. and no consistent amount of change - a drifting of time .. i have not been using it since i found this .. i asked them about this and they told me it was Normal .. all pitch programs do this .. well .. Autotune has the same thing ... and they said the same thing .. not buying that as .. Revoice has a locking feature so you do not change the timing of your tracks .. i need to get a fresh demo and test this more .. so, i am fine if PT gets this Feature .. BUT BUT BUT lets have this timing issue fixed FIRST ... cheers john
Pro Tools First Compatibility with Melodyne Essentials 4 | rgpinder | Pro Tools 12 | 1 | 03-11-2017 07:43 PM |
Alternative to Melodyne for Audio to MIDI? Or Which Melodyne version? | DBK | Getting Started | 6 | 12-15-2014 11:33 AM |
Melodyne Users - Melodyne Editor Beta release imminent! | Driven01 | Pro Tools M-Powered (Mac) | 2 | 09-18-2009 06:31 AM |
Melodyne Users - Melodyne Editor Beta release imminent! | Driven01 | Pro Tools M-Powered (Win) | 2 | 09-18-2009 12:15 AM |
Melodyne and Protools 6 compatibility. | kizzer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-26-2008 09:35 AM |
