MIDI program change
I am getting inconsistency when putting in program changes between sessions. One session will give the correct program change and another will give a change of +1 from the number selected. So 3 means 4 is selected and so on. Is there a setting to select 0-127 or 1-128 somewhere?
Mac Mini M1 16 GB OS 12.7.4 PT 2024.3.1 |
Re: MIDI program change
The patch select dialog in PT goes from 0-127. Is it the same gear involved between sessions?
Yes, it is the same guitar preamp that responds differently to each session. If I import the midi into a clean session, it then displays a value of +1 on the program changes.
I could go through and change them all by hand, but there are a lot and I would like to get to the bottom of what makes the difference.
I'm pretty blank in this area, as I stopped using outboard MIDI gear years ago, but I noticed that the PT 10.0 manual shows 0-127 (Patch select), but the 10.3.9 session I'm working on shows 1-128. The PT 11 manual shows 1-128, but it states "The MIDI protocol lets you choose from a range of 128 programs (0–127)". I'll try to investigate some more.
Thanks for your time Stig. I did find this, which suggests there is a problem, but no way of adjusting it.
http://avid.force.com/pkb/articles/e...n&DocType=1081
Program change via MIDI on PT7 | JSPurcell | Tips & Tricks | 1 | 09-12-2010 11:19 PM |
problem with midi program change | Riccardo Corbari | Pro Tools TDM Systems (Mac) | 9 | 02-22-2006 09:06 AM |
midi program change | porkipine | MIDI | 3 | 05-14-2005 04:52 AM |
Midi Program Change Bug? | Nocturnal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-28-2002 05:54 PM |
Midi program change on the fly | GaryGarris | Pro Tools TDM Systems (Mac) | 5 | 11-16-2000 10:20 AM |
