Old 06-16-2012, 08:19 AM
jeremyroberts jeremyroberts is offline
Default Re: Hackintosh - Salvage your HD PCI cards - You Can Do It Too!
Why Lion 10.7.4 ? A personal choice ?
1. ease of installation
2. compatibility with the world. PT 10.2 HD is compatible
3. i'm using Lion on all of my other machines. I wanted the features. I use iTunes match, iCloud, etc...
4. why not install the latest stable release?
5. see #1 -- with UniBeast, there is no need to install from dvd and then upgrade. If you read the installation guides for 10.6.x (for hackintosh) - it sounds like geeks designed this for themselves. As opposed to UniBeast which is as close to one-click as you're gonna get.
I saw no need to install an OS that is "obsolete". But #1/#5 were the most important factors (in addition to the others).
Why WOULDN'T I want to be in the latest stable OS that's compatible with my software for a new build?
--Jeremy
Old 06-16-2012, 08:58 AM
jihel's Avatar
jihel jihel is offline
@ Jeremy
Thx for these explanations and your time.
Mac Mini Server (mid 2011) Core i7Quad - OSX 10.11.4
Pro Tools 12.6
Old 06-16-2012, 06:23 PM
Philthy Philthy is offline
Great thread, thanks very much.
Phil Mann
Silk City Music Factory - CT Recording Studio
Old 06-17-2012, 02:11 PM
fatcode fatcode is offline
Great stuff ! Thanks you very much !
Old 06-17-2012, 05:59 PM
abomeerza abomeerza is offline
Now I moved to Mac, but in the past
I was working on hackintosh
And I was working on HD 5 with magma per64and protools HD 10.2
Mac OS X 10.6.8
and Did not have any problem and the every things is working strongly and efficiently
Intel i7 2.93ghz
MB asus 7P55D
16 DDR3 1333
Geforce 8400GS
AVID HDX , Pro tools Ultimate 2021.6 , Avid C24 , Lynx Aurora 16 (n) , mac pro 12 core , Mac OS Mojave
  #16
Old 06-18-2012, 12:15 PM
studiojimi's Avatar
studiojimi studiojimi is offline
hackintosh has risky support challenges
that's why i chose to buy a westmere 8 core
i didn't think i need a 12
besides i found a killer deal on an 8 core with 18month left of applecare
and he included a ton of plugins...too sweet of a deal for 3K
now if i can find someone to take this P7R4 off my hands
as now i have the P6R4
there are a lot of PT users who now want lap tops instead of towers
if you can find a guy like that... you may find it a blessing.
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
  #17
Old 06-18-2012, 12:43 PM
Jimmy,
What kind of support challenges would you consider "risky"?
I've been a mac customer for 26+ years. We (mac users) have been brainwashed into "mac religion" -- that if the hardware is not mac, it's risky -- and that has been the way it is... but once you understand what really is inside your box, you will realize there are few risks.
Yes, initial installation and configuration can be considered "risky". HOWEVER - using verified configurations and components has turned this into a no-brainer.
If your mac logic board should fail out of warranty, you are looking at a costly repair. If my mobo fails, I can pop another one in ($200 or less)
What is "risky" to me should also be risky to you -- OS upgrades. And I will give the same due diligence that you will before doing any OS updates.
I don't see any risk.
--Jeremy
  #18
Old 06-18-2012, 12:50 PM
Drew Mazurek's Avatar
He means calling Avid for support I think. Any issue you have can immediately blamed on your computer.
www.drewmazurek.com
  #19
Old 06-18-2012, 01:08 PM
Ah... but I think the last time I called Avid for support was 2005.
Don't know if people realize that once the bootloader does its thing, the machine becomes a Mac in every way. So if I run Digitest, it's the same as running it on a mac, etc...
--Jeremy
  #20
Old 06-18-2012, 01:48 PM
TornadoTed TornadoTed is offline
I have gone ahead and ordered the same parts as in your machine today. I appreciate so much that you have shared this info as my head has been swimming with possible options for months. I have been curious about a Hackintosh but scared off even though I have built several PC's in the past before I got my current Mac. The new multi-beast plus your full parts list really has simplified things so much.
I have a 2006 Mac Pro with HD4 PCIx in a 4 slot Magma chassis which works ok but I do run out of native power. The one option I didn't want to dive into was HDX, the transition over the next 2-3 years looks messy to me and I wanted no part of it. Plugins going/not going to AAX, Pro Tools going to 64Bit etc. Besides that I use 3 interfaces for 48 i/o so I would have needed to go HDX2 because they only have 2 ports per card. That would add another £4k to the cost which is just too much.
I had set my mind on getting a 2nd hand Mac (2009 model) and going to 10.2 and staying there. That still wasn't that cheap a solution, especially as a stop gap. By building a Hackintosh I can get rid of my Magma as HD4 would fit on the Motherboard, by the time I sell that and my Mac I may nearly break even. I will get a more powerful machine and a simpler set up (no Magma), a perfect stop gap machine for 2-3 years until everything settles down and there will be decent 2nd hand deals of HDX on eBay etc.
Hackintosh - Salvage your HD PCI cards - You Can Do It Too! jeremyroberts macOS 2 07-01-2016 09:32 AM
Hackintosh on my rig? Raoul23 Pro Tools TDM Systems (Win) 7 07-01-2011 03:26 PM
Hackintosh Help HDK_Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-16-2010 10:45 AM
Get a laptop or salvage old machine?? Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-24-2008 01:28 PM
OT - Salvage a bad DAT - Possible? soundsurfr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-08-2003 12:55 AM
