"Low latency monitoring" which interface?
I own Mbox 2 pro which when enabled as my interface can use 'low latency monitoring'. However my friend has got the Apogee Ensamble and there is no such feature in PT9 when that interface is enabled What similar interface would you suggest which can use the feature? Thanks in advance.
Mac Studio M1 Max 32/512, 2x 2TB 40Gbps + 2TB 10Gbps, 13.6.5, Logic 10.8.1, PT Ultimate 2024.3, Mackie Big Knob Studio+ |
Re: "Low latency monitoring" which interface?
As far as I know, that feature is only available to certain Avid/Digidesign interfaces.
Have you tried lowing the buffer rate to 64 or 32 (if available). I haven't used LLM in years now... since none of the artists I record can tell the difference at 64 buffer.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
OK, thank you. We'll try it. I don't know his machine's specs but probably it's capable of setting the 64.
Ask you friend if he's tried the Maestro software. You can jerry-rig an no-delay solution with that for the Ensemble. It just means you have to have another app running to monitor the Ensemble.
I had a kick ass machine and no matter what I could not get a stable result with less than 256 buffer with my ensemble.
The machine can handle it, the drivers and pt can not. I made the switch to a Apogee symphony 32 pci-e card and rosetta 800. Luckily I have good pre's so the loss of the Ensemble pres didn't mean to much to me. I have to say that now I can track all day at 64 with VI's running and a ton of plugs and it is STABLE. I Love apogee, but the Ensemble just didn't cut it. If he has the money and can sell the ensemble and doesn't need pre's. Tell him to do what I did... he will never miss it!!! |
I record at 32 buffer with my AES16 and Aurora 16
(Mixing at 512 to get my UAD2 pluggins to work flawlessly)
Regards www.h-musikk.no/english.html Norway ASUS X99-E, Intel Core i7-6850K, Noctua NH-U9S, Corsair Vengeance LPX DDR4 2133MHz 16GB, Samsung 960 EVO 250GB M.2 PCIe SSD (System), Samsung 850 EVO 500GB 2.5" SSD (Data), Samsung 850 EVO 1TB 2.5" SSD (Sample), WD Desktop Black 1TB 3.5" (Audio), Gigabyte GeForce GTX 1060, Corsair RM750x 750W, Samsung 34" LED Curved, Windows 10 Pro 64-bit, Lynx AES16e, Aurora 16, Cakewalk by BandLab, Pro Tools 2021 |
Back to Ensemble. I would be interested if he can run at 128 or lower without pops and clicks. |
yes. W7 64bit
DAW: MB: ASUS P6T SE, X58, Socket-1366 DDR3, ATX, Firewire, GbLAN, 3xPCI-Ex(2.0)x16 CPU: Intel Core™ i7 Quad Processor i7-920 4,8GT/sec, 8MB, Boxed CPU fan: Noctua NH-U12P SE1366 CPU Fan Socket 1366, 19,8 dBA Graphics card: EVGA GeForce 9500GT 1GB PhysX CUDA PCI-Express 2.0, DDR2, 2xDVI, HDCP, Graphics Plus Power supply: Corsair TX 750W PSU ATX 12V V2.2, 80 Plus, Standard. 4x 6+2-pin PCIe, 8x SATA, 140mm Vifte HD: 1 stk. Western Digital Caviar® GreenPower™ 1TB, Sata 3 Gb/s, 32MB Cache, 2 stk Western Digital Caviar GreenPower 500GB, Sata 3 Gb/s, 32MB Cache Memory: Corsair Dominator DHX+ DDR3 1600MHz 6GB Kit w/3x 2GB XMS3 modules, CL8-8-8-24, for Core i7 Monitor (x2): Samsung 23" LCD Syncmaster 2333SW (x2) Soundcard: Lynx AES16
Yeah, Macs to my knowledge do not go below 64 with 3rd party gear. Ensemble is a mac only device as well.
"Low Latency Monitoring" with 3rd Party Interfaces | RokVox | Pro Tools 11 | 10 | 03-02-2016 12:52 AM |
Still can't find "Low Latency Monitoring" in my menu options... | finalcut | Pro Tools 10 | 13 | 02-20-2013 11:52 AM |
Where did "Low Latency Monitoring" go? | finalcut | Pro Tools 10 | 2 | 12-30-2011 05:53 PM |
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface | eanderso22304 | macOS | 3 | 11-23-2011 06:45 AM |
How to activate "Low Latency Monitoring" on 003+, LE 8.0.3 | aidan7737 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 40 | 06-11-2010 08:16 PM |
